Author Topic: Ring gear teeth  (Read 1674 times)
Offline Vincent
  • 1953 WO CJ3a
Ring gear teeth
« on: June 23, 2019, 04:13:14 PM »
From what I�ve found out, the ring gear on my 1953 CJ3A should have 124 teeth. The one I just removed from the flywheel has 129 teeth. It had sat in a field for 20 years before I got it and it looked like someone had changed it to 12 volts. Would that require a different starter, and also replacing the ring gear? I want to restore to original 6 volt. So do I now get a 124 tooth ring gear and the appropriate starter, or am I wrong and this could be the original ring gear with 129 teeth?
Vincent S.
vschleg@yahoo.com
Offline stony
Re: Ring gear teeth
« Reply #1 on: June 23, 2019, 06:40:24 PM »
Right here on the tech page:   http://www.cj3apage.com/index/Tech_Tips.htm
Terry
Offline Vincent
  • 1953 WO CJ3a
Re: Ring gear teeth
« Reply #2 on: June 23, 2019, 09:57:25 PM »
Thank you. I need to read more.
« Last Edit: June 23, 2019, 09:59:48 PM by Vincent_S »
Vincent S.
vschleg@yahoo.com
Re: Ring gear teeth
« Reply #3 on: June 24, 2019, 08:45:45 PM »
What is the serial number of your CJ-3A. Some of them had 129 tooth ring gears with the appropriate starter at 6 volts.
Offline Vincent
  • 1953 WO CJ3a
Re: Ring gear teeth
« Reply #4 on: June 29, 2019, 12:01:54 AM »
#12268. It also has a key ignition. The tech page explains it all. 129 teeth ring gear and a different starter. Thanks.
Vincent S.
vschleg@yahoo.com
