Ok guys I've read the wiring diagram and other than the lights which aren't important because I am waiting on the new switch I have all the wire run to the AMM gauge, fuel gauge, etc. My problem however is this cj3a is a 12V conversion. Alternator, 12V battery, etc. I run the positive cable from the battery to the starter and a wire from the starter to the AMM gauge.....the jeep cranks a runs fine as long as the AMM gauge is hanging out of the dash...if I put the AMM gauge in the dash and start to crank it the gauge starts arching fire off the dash. Is the AMM gauge supposed to have a rubber ring or something to keep it from doing this???
I have ordered a whole new set of 12V gauges from Kaiser/Willys but I would like to make sure the wiring is correct and if the gauge is just faulty.
