Author Topic: brake fluids?  (Read 3517 times)
Offline MikeP
brake fluids?
« on: July 25, 2019, 07:03:42 PM »
so i got to thinking about my brakes and what i should use seeing as i live in the northeast (more moisture) and i plan on daily driving the jeep up to 60 mph i was told to use dot 5 however there is also dot 3 and dot 4 and super dot 4 dot 5.1 etc now my current brakes and lines probably had dot 3 in it since it was last registered in 1979 but im sure everything is gone from the lines as the pedal has zero resistance whats your guys input
« Last Edit: July 25, 2019, 07:18:32 PM by Roughneck20 »
1950 willys cj3a
Re: brake fluids?
« Reply #1 on: July 25, 2019, 09:36:23 PM »
From what I've read, you probably should consider flushing the lines and cylinders out with alcohol to remove any moisture and fluid trapped in the lines.  I have also read one should NOT mix types of fluids in a system.  Each has it own purpose, so research and pick to your "needs", is my best suggestion.  PS, brake lines can deteriote from the inside out, unless exposed to salt, etc.  My lines looked good, pedal was tight, then I found the rear line was solid... no rear brakes!!!  Be careful with the brakes if intending daily traffic at 60MPH!!!
Re: brake fluids?
« Reply #2 on: July 26, 2019, 09:01:08 AM »
DOT 3 will work just fine.  Maintenance is necessary.
As noted extreme care not to mix is necessary for DOT 5.  There are some advantages.
Cost and maintenance should be the driver.
I personally use DOT 3 as it's easy.  I did let the system sit too long (still working out problems keeping me from driving it and retiring/moving/storage) and I needed to rebuild the rear wheel cylinders (with the mindset the same thing will be smart for the front and m/c).  If I'd have kept up with better maintenance (in this case - flushing)  I don't think I'd have had these issues so soon.
Offline mtnman37879
  • Plays With Jeeps
Re: brake fluids?
« Reply #3 on: July 26, 2019, 10:02:06 AM »
I use DOT 5 in everything I own. One example is a 1964 Ford Van. It has been sitting for 12 years. The brakes are working fine. I have a harley, 1968 FLH, in my collections that has been sitting for 19 years in the same spot. It has DOT5 and it's brakes are just like new. DOT5 does not attract water it repels it. DOT5 is silicone based. Silicone and water will not mix. All the others are alcohol based and will attract water and eventually will rust the insides of your brake system. Spend the extra few dollars, it's worth it.
Offline Mark W.
  • Chug A Lug
Re: brake fluids?
« Reply #4 on: September 15, 2019, 05:03:16 PM »
You should only use DOT 5 fuild if everything in your brake system is virgin. MC all lines and fittings all hoses and wheel cylinders.
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
Offline tow hook
Re: brake fluids?
« Reply #5 on: July 24, 2020, 11:15:28 AM »
fyi dot 5 collects more moisture, as per the bottle for my British car
