Author Topic: Brake Upgrade for CJ3A  (Read 15022 times)
0 Members and 7 Guests are viewing this topic.
« on: February 06, 2018, 09:06:17 AM »
Gents,
Looking for some advice from the "A Team" here.  I've got a set of factory brakes on my 50 3A, I have nev er been happy with them.  They seem to require continual adjustment and service, the brake pedal is hard to push and it just seems that they are much less effective than they should be.
I've got two roads to go down here, I can tear the brakes a part and do a complete factory re-build, my fear is that I will end up with what I have now, or I can do an upgrade, what do you guys suggest?  Does anyone have a good upgrade that is relatively easy to install?  What are your thougths, looking for suggestions.
Gun
Offline mtnman37879
  • Plays With Jeeps
Re: Brake Upgrade for CJ3A
« Reply #1 on: February 06, 2018, 04:58:19 PM »
I'm currently restoring a 1950 CJ3A and I have decided to go with 11" brakes all around. The stock 16" wheels fit over these brakes. I'm using 1972 CJ5 brake parts. The other option was disc brakes from a GEO Tracker. i bought the bolt on  brackets to hold the calipers and the rest of the parts are stock Tracker. The reason for not going this way was that the stock 16" wheels do not fit over the caliper.
« Reply #2 on: February 11, 2018, 07:20:31 AM »
With 11" brakes it will stop on a dime and there is very little modification that needs to be done to make them fit.
« Reply #3 on: February 11, 2018, 11:47:46 AM »
I have the 11" brakes also and am very happy with them.  Be advised that the primary shoe is in the opposite position as with the 9" brakes.  I am forgetting which is which, but I believe the primary shoe goes in the rear position whereas it is in the front position on the 9" brakes.  But don't take my word for it! :-?
Offline 64CJ5
« Reply #4 on: February 13, 2018, 12:38:51 PM »
Several years ago I got an 11" kit from Mile High Jeep in Denver for our CJ5.  They stop the Jeep with authority.  I am very happy with this up grade and I am planing on putting the 11" brakes on my 52 M-38.
« Reply #5 on: February 20, 2018, 06:53:46 PM »
Thanks guys, couple questions, the 9 and 11 inch brakes mentioned here, are these the size of the brake shoe using the original drums, and master/ wheel cylinders or are we talking about a set of disc brakes with external calipers and discs?  Additional Qusetion, Mile High Jeep in Denver, do they have a web site?  I looked for them and they didn't come up in a google search.  Thanks Gun
« Last Edit: February 20, 2018, 06:56:08 PM by Gunslinger »
« Reply #6 on: February 20, 2018, 08:44:38 PM »
Drum brakes are measured by the inside diameter of the brake drum. 9" is stock for an early CJ. In the '70s CJs went to self adjusting 11" drum brakes. This is what most 11" conversion parts are based on. Early Wagons and Trucks also used 11" brakes but they are less desirable.
« Last Edit: February 20, 2018, 08:45:14 PM by Bob_W »
« Reply #7 on: February 21, 2018, 09:09:31 PM »
Gun,
Sadly, Mile High Jeep is long gone.
Offline Dutch_Jeeper
« Reply #8 on: March 02, 2018, 01:38:36 PM »
I'm in the middle of planning and sourcing parts to upgrade to discs all around. There is some great info for it here https://g503.com/forums/viewtopic.php?t=236383
Depending on where you can get the parts, right know i'm looking at around 450-600 dollar for all the parts as good as new or new included having the brackets made.
The good thing about this upgrade is you do not need to grind anything off the knuckles, no extra drilling welding anywhere, simple bolt on upgrade so you can always go back easily if ever originality becomes a priority.
The way i look at it personally is the extra safety this provides in stopping power does not justify sticking to originality and drumbrakes if you participate in modern traffic on a regular basis. Not only for you and your Jeep but others also.
« Reply #9 on: March 02, 2018, 03:19:48 PM »
Guys, I found this guy, just doing some research but it sounds promising, no cutting welding or drilling.  Keep you posted.
Gun
Sent: Wednesday, February 7, 2018 11:21:22 AM
To: 'Todd and Sue Gabrielson'
Subject: RE: Brake conversion- upgrade kit for CJ3a
$695.00, most of the parts are 1978-81 CJ parts
-Don
Offline mtnman37879
  • Plays With Jeeps
« Reply #10 on: March 02, 2018, 05:11:28 PM »
 Suzuki GEO Tracker Disc Brakes Easy disc brakes. Bolt on, no cutting or grinding. All the parts are at any auto parts store. Get the mounting brackets here:
https://www.facebook.com/brennan.metcalf.37/posts/762109110580994
« Last Edit: March 06, 2018, 09:32:23 PM by mtnman37879 »
« Reply #11 on: March 03, 2018, 05:19:20 PM »
Guys, I found this guy, just doing some research but it sounds promising, no cutting welding or drilling.� Keep you posted.
Gun
-Don
The only problem with using those parts is that you have to grind down the knuckle. Very similar to this upgrade:
http://www.fourwheeler.com/how-to/transmission-drivetrain/154-0704-early-jeep-disk-brake-conversion/
Personally the last thing i want to do is having to grind down the knuckle to make it fit, and a pretty fair bit to if you ask me. Going the Suzuki Geotracker part way does not require any grinding and makes this imho the best upgrade with respect to your Jeep. Anything that requires to cut into original parts that cannot be undone ever is a no go imho.
« Reply #12 on: March 04, 2018, 09:23:25 AM »
Here's the product description from the web site, curious as to what you guys think.
Gun
Product Description
Disc brake kit for Dana 25/27 closed knuckles axles. This kit is designed to work with 15" stock Jeep rims that came with drum brakes and requires no grinding to the knuckle.
Wear parts in this kit are over the counter parts that can be purchased at any auto parts store. Part numbers for these parts will be included in the kit as well as the vehicles that use these parts. Kit designed to work on all stock 15" Jeep rims. No grinding necessary to the knuckles with this kit. Kit includes detailed mounting instructions, 2 preassembled 7/8" rotors, wheel hubs and wheel studs, 4 Timken bearings, 2 seals, 4 bearing cups, 2 1/4" aluminum wheel spacers, 2 standard rubber brake lines, 2 caliper mounting brackets, 2 loaded calipers with pads and hanger brackets, 10 wheel lug nuts, 2 wheel spindle nut kits, 2 banjo bolts, all the mounting hardware needed to install this kit.
Warranty Information
null
Find Similar Products by Category
    1967-71 JEEPSTER COMMANDO
Write your own product review
Product Reviews
    Disc brake kit 5 Star Review
    Posted by Darin on 11th Jan 2017
    Fantastic kit. Wish I would have done this a long time ago. Easy and simple to install. Everything bolts right on. I spent maybe three and a half hours, taking my time to install the kit. I had driven it is snow and rain with no more pulling from one side to the other with lots of stopping power. Thanks Don!!!!!!!!!!
    Can't wait to buy more of your products.
    disc brake upgrade 5 Star Review
    Posted by Darin on 1st Jan 2017
    Fantastic kit! Everything bolts right on, simple and easy. Spent a few hours Sunday afternoon, and what a difference. Wish I would have done this years ago.
« Reply #13 on: March 04, 2018, 11:27:36 AM »
They mention only 15" wheels.  Do you think they are saying it won't work with 16" wheels?  Why would that be???
« Reply #14 on: March 06, 2018, 08:34:48 AM »
They mention only 15" wheels.� Do you think they are saying it won't work with 16" wheels?� Why would that be???
That seems to be a consistent message on these brake conversions, I looked at Herms site yesterday and was pretty excited about his options.  He offers an 11 inch drum brake kit for all 4 wheels that includes a dual reservoir master cylinder for about 800 bucks.  But there is a warning that "some original 15 and 16 inch wheels may not fit on the drums".  I think I'm going to call them and get more info before I dive in.  I would hate to be surprised by needing a wheel purchase.
