Author Topic: Rear Brake swap on a CJ3A??  (Read 1279 times)
Offline Hotdutch1951
« on: July 02, 2018, 07:11:50 PM »
I know I can go to disc brakes on all 4corners but then I loose the E-brake as I will also be replacing the transmission ans transfer-case.  So I have heard about 10" and 11" rear brakes but have only found 11" one so far and no parking brake setup.
   If I did the rear disc brakes I could go with a Manual Caliper for a parking brake on each rotor or a hydraulic caliper like Total Performance did on there T-Buckets that mount to the rearend.
1951 CJ3A with Stock Flathead engine
Frame off rebuild coming up .
Needs to be able to drive
everyday to work for my
Stepson
