Author Topic: clutch pedal shaft  (Read 3481 times)
Offline RandyA
clutch pedal shaft
« on: June 02, 2018, 04:51:14 PM »
Gents... Hey me again....another dumb question...Putting in new brakes and clutch pedal shafts...after bolting everything in... brake pedal shaft is about a half inch off from being close to center on tub floor... Can I bend that rascal somehow... I know its cast and that's my concern... any other adjustments? As always.. Thanks for all your help... Randy A.
Re: clutch pedal shaft
« Reply #1 on: June 02, 2018, 05:32:56 PM »
Just something to check Randy...is it adjusted over to the side on the shaft as far as it can be?  You may be able to slide it one way or the other by shifting the big washers around.  You can snug it up nice too with washers without having to fab that threaded tightener that a lot of the guys have made.
Offline RandyA
« Reply #2 on: June 03, 2018, 11:39:22 AM »
Yes Sir have it moved over as much as I can... tried putting a little pull on the pedal shaft last night and I think she moved over enough .... Gonna try and crew everything tight this morning and find out if that worked... Thanks...
« Reply #3 on: June 03, 2018, 12:38:15 PM »
Hi Randy,
I believe that most of us that have replaced a brake pedal arm have been forced to modify/bend the arm to match the hole in the tub.
I used an acetylene torch and a bunch of "trial and error". :(
Offline LKap
  • Jeep Fanatic
« Reply #4 on: June 03, 2018, 03:32:41 PM »
Randy,
I just completed this process a few weeks ago with a new brake pedal arm.  I do not have a oxy-acetylene setup and MAPP wasnt hot enough.  I went to Home Depot and got a Bernzomatic MAPP-Oxy kit.  Worked perfectly.  Took a couple tries but it got it just hot enough to bend.  Buy a few extra oxygen tanks as they run out VERY quickly.
Check out the thread in the Tech Talk section - "Brake and Clutch Pedal Arm Question"
Offline RandyA
« Reply #5 on: June 05, 2018, 10:52:45 AM »
Thanks all....
Offline RandyA
« Reply #6 on: June 29, 2018, 10:32:07 AM »
Well shoot... That didn't work..... Tried heating a new rod and it  just broke in half... Used a small rose bud, Got her red hot... just barely put a pull on it... and she snapped in half... New ones coming... Not doing something right... Randy A.
« Reply #7 on: June 29, 2018, 12:28:36 PM »
Well shoot... That didn't work..... Tried heating a new rod and it� just broke in half... Used a small rose bud, Got her red hot... just barely put a pull on it... and she snapped in half... New ones coming... Not doing something right... Randy A.
Which rod???
« Reply #8 on: June 29, 2018, 01:03:42 PM »
You broke this????
« Reply #9 on: June 29, 2018, 02:42:17 PM »
The arrow is pointing to a brake pedal arm.
A Willys brake pedal arm is cast steel and will bend well if heated to proper temp.
A Willys pedal shaft is steel and is assembled to the pedal pad.
Red to dull orange is ideal for bending either the shaft or  the arm.
If yours broke perhaps it was an aftermarket part made of cast iron.
Offline RandyA
« Reply #10 on: July 01, 2018, 04:32:44 PM »
Yes Sir I broke that... bought from Kaiser.. Just received another one in the mail...I'll give er another try.... Kinda wish my Willys was that nice looking... As always Thanks to all... Randy A.
Offline RandyA
« Reply #11 on: July 02, 2018, 01:34:11 AM »
That did it... Must have gotten a bad one earlier... Thanks all...
