Author Topic: Frame Repair Help  (Read 5906 times)
Offline LKap
  • Jeep Fanatic
Frame Repair Help
« on: March 18, 2017, 08:37:16 PM »
I need some advice on the best way to fix my front frame horns.  The PO had welded the bumper to the frame and it took awhile to cut it off without destroying the frame.  As you can see there are quite a few cracks that need to be welded up.  I was thinking about boxing the frame above the shackle mounts after welding the cracks.  I'm considering cutting the ends off at an angle and putting gussets on - 2A style. Any other ideas?
Re: Frame Repair Help
« Reply #1 on: March 18, 2017, 09:54:45 PM »
My humble opinion...I suppose anything can be done, but it would be much easier to repair the existing horns than to convert them to accept the 2A gussets.
« Reply #2 on: March 19, 2017, 06:48:08 AM »
I'm with Tim. I'd repair what you have there. M-38s had boxing in that area so you could copy the way Willys did it if you want to add boxing.
Offline LKap
  • Jeep Fanatic
« Reply #3 on: March 19, 2017, 09:58:04 AM »
Thanks for the advice! I think I'll try to repair them as is then.  I'll post pics once I'm done. No way it'll look as good as Hawk's though  ;)
Offline LKap
  • Jeep Fanatic
« Reply #4 on: April 11, 2017, 10:38:06 PM »
So I finally got around to fixing the frame.  Took your advice and decided to keep what I had. Welded up the cracks, added a piece to fill the void. I was a bit concerned about the overall strength of this section of the frame because it sees a lot of load from the shackle mounts - so I boxed it in.  This is one of my first major welding projects and although a bit ugly I'm pretty happy with the results.  Comments and criticism is welcomed!
« Reply #5 on: April 12, 2017, 12:57:48 PM »
Your welds look better than mine.  Nice work!
Offline LKap
  • Jeep Fanatic
« Reply #6 on: April 13, 2017, 09:44:46 PM »
Thanks!! You are way too kind
