Author Topic: FRONT DISK BRAKE CONVERSION  (Read 4394 times)
Offline Jimmy Fehr
  • Willis II
« on: July 13, 2015, 06:10:17 PM »
Does anyone have a parts list of what I will needs to convert over to disk brakes. I understand that I can use a 1973 - 78 Chevy 4x4 1/2 ton callipers and rotors and then longer studs? Do you have to change out the master cylinder. Any advice is appreciated. Thanks
Re: FRONT DISK BRAKE CONVERSION
« Reply #1 on: July 13, 2015, 07:35:42 PM »
I'm of no help, but I do know that Jpet on the 2A page just did a 4 wheel disc conversion.  If you search there he may have documented the project, I don't know for sure.  Otherwise just pm him and I'm sure he will help you out.  Good luck, share your project with us if you can.
Offline Jimmy Fehr
  • Willis II
« Reply #2 on: July 14, 2015, 09:25:17 AM »
Thanks Tom. I will try to get in touch with him.
« Reply #3 on: July 15, 2015, 11:21:32 AM »
You mounting onto a Dana 25/27 or ?
Offline Jimmy Fehr
  • Willis II
« Reply #4 on: July 15, 2015, 11:27:50 AM »
It is the stock Dana 25/27.
