Author Topic: After market Body mount problem.  (Read 2233 times)
Offline DonS
« on: January 06, 2018, 04:17:38 PM »
This is my first post. Hope it goes right as I'm kinda old school and have never belonged to a forum before.  I purchased a body kit for my 3A and am thinking MDJuan is the supplier for Omix-Ada as there is reference to both in the shipping container.  My issue is the body mount location on the frame doesn't line up with the floor brace's. The front frame mounts are a couple inches off and the middle and rear mounts are a 1/2' off. Just looking for some advice before I start moving mounts or floor braces. It appears the body needs to move forward. Finders alien good with the grilled fenders mount correctly with the frame. Has anyone experienced this problem. Appreciate any help i can get.
ledfoot
Re: After market Body mount problem.
« Reply #1 on: January 06, 2018, 04:31:00 PM »
You should get some good info here - a lot of guys have fit these tubs.  All I can offer is the rear of the tub should be flush to the rear face of the rear bumper.  I guess I'd use that as a start point and see where you are.  It sounds like you will have to be moving some mount points one way of the other.  Good luck...sorry I can't be of more help.
Offline DonS
« Reply #2 on: January 07, 2018, 09:35:34 AM »
Thanks for the reply, The rear of the body does line up with the rear bumper. The only issue i see is on the left frame rail one of the mounts would have to go over where the clutch and brake shaft is mounted. The bolts for that would interfere with the mount.
ledfoot
