Author Topic: Mig welding tack  (Read 4334 times)
Mig welding tack
« on: August 09, 2016, 06:58:26 AM »
Does anyone have any insight to why my tack welds seem to have a hole in them?
It's annoying
Re: Mig welding tack
« Reply #1 on: August 09, 2016, 09:36:50 PM »
Contamination. Not enough shielding gas, dirty metal?
« Reply #2 on: August 09, 2016, 10:27:49 PM »
I agree with Bob....
Clean the area thoroughly..I even used denatured alcohol to remove grease/oil etc...
Are you purging the gas supply line before starting to weld?
If you are filling holes or if the tack holes go through both pieces of metal you need to "back" the opening with copper( a flattened piece of copper pipe works great) or aluminum. This prevents air/oxygen from reaching the weld from behind.
Offline Roger
  • Camaro guy trying to figure out Jeeps
« Reply #3 on: August 10, 2016, 12:10:19 AM »
That looks like some of my welds when I forget to turn on my gas bottle. ::)
But as mentioned before... contaminants from the backside may be causing grief.
1953 CJ3A (Navy)
1953 356 Porsche
1957 Chevy PU
1969 Chevy RS Camaro
1977 2WD Blazer
« Reply #4 on: August 10, 2016, 09:43:27 AM »
Bob W, Rodger Thank you for the advice, I thought I only needed "backing" when I had a larger gap... I will try this out Friday, thank you so much!
Kirk
Offline JeepFever
« Reply #5 on: October 02, 2016, 11:10:29 PM »
I am far from expert,� but as others have mentioned,� my first thought was lack of shielding gas.
edit:  just realized this thread is kinda old.  :-[  . . did you figure it out?
« Last Edit: October 02, 2016, 11:12:25 PM by JeepFever »
« Reply #6 on: October 03, 2016, 06:51:43 AM »
 I posted this on my build page, but should be here as well, since I did start this thread about it...
When I started this project I had no welding experience with MIG. I thought all of the issue I was having was me and my technique.
Turns out after burning through a 2 lb roll of wire that my boss got me from "Advanced Auto Parts" my welds looked no better, had little penetration and I had to grind my backside off to make them look decent..
Well, I went to a local welding supply house and I picked up a new roll of the same spec wire size, grade etc... and what a difference it made..
Beautiful welds, nice penetration and easy clean up... Boy did I learn a valuable lesson... Don't buy crappy wire...
Offline JeepFever
« Reply #7 on: October 03, 2016, 10:37:58 AM »
I saw your post about the crappy wire in your build thread,  and did not tie the two together.  haha
Speaking of wire,   that got me thinking,  I have some wire in my welder now that results in a weld that is tough to grind.   I have another roll on the shelf that I think is softer.   (the wire itself is easier to bend).
I probably should have tried this a long time ago.   haha   . . but,  I still have quite-a-bit of welding to do.   I can save the hi-tensile wire for structural projects.
Only reason I have hesitated so far,  the soft roll is .030,  and the existing is .025.  . .   does anyone weld sheetmetal with .030?
« Reply #8 on: October 03, 2016, 10:41:34 AM »
JeepFever All my welding was .030 wire
