Author Topic: Keep me from going insane  (Read 4257 times)
Offline Mudviper
« on: June 08, 2016, 09:54:45 PM »
I purchased a 52 CJ3A a couple months ago. It is in really good shape and runs pretty good. I have been trying to replace some of the warn out parts and do some upgrading, but I seem to be wasting money do to the fact what I think I am ordering for my engine, doesn't seem to work of fit on my engine. Help keep me from going insane and help me identify what engine. Here are a bunch of pictures of the engine bay
The number on the Head is 800370 and according to what I have read that is a Head for a M38 engine, but the serial number on the block above the water  pump is 3J143B79, which from what I understand is a CJ block. The Head also as a neck on the back of it that looks like a bypass for the coolant. I have not seen this on other CJ engines.
It has a IAT 4008 vacuum advanced distributor, but the person that had it before me didn't run the vacuum advance on it. I took the starter off to get access to the timing window, but it doesn't have one. The front pulley has a nick in it that is used for setting the timing.
I went to replaced the radiator cap, but the one that is supposed to be for the CJ3A is a lot bigger then the one that I found that fits the radiator, so I am not sure what radiator I have. It is a side mount that mount.
Any help you guys could give me so I know what parts to order would help out a lot.
Re: Keep me from going insane
« Reply #1 on: June 09, 2016, 12:13:36 PM »
[size=12]This is typical of what we in the hobby refer to as a �Jeep Salad�. You�ve got a hodgepodge of parts from various jeeps of different years and models. Unfortunately yours is a slow and sometimes painful task. There is a port in the throttle base where you can draw vacuum for the distributor. Also, at your earliest opportunity, you need to rebuild the PCV system. That small filter on the oil filler tube will cause you more problems down the road as air is supposed to flow out of the tube and into the air cleaner�s crossover tube.[/size][/b]
Offline Mudviper
« Reply #2 on: June 09, 2016, 12:23:24 PM »
I found a port on the Carb that has a vacuum when the engine revs but no vacuum at idle. I was going to use that port, but I tried to find a adapter to fit the distributor so that I can connect the vacuum hose to, but I can't find one. I have a new solid state distributor coming in tomorrow, so the vacuum one is going away.
Good advice on the oil filter tube. That was my mistake putting that on. When I was doing some research on that I was shown a diagram where that was an air inlet not an air outlet that is why I put the filter on it. I didn't want a bunch of dust being sucked in to the oil. Working on finding a stock air intake system, but those things are not cheap...lol.
« Reply #3 on: June 09, 2016, 01:57:24 PM »
3J143B79  Is the �B� possibly and �8�?  If so, this is  a very late 3A block...Possibly a very early DJ3A block.  I don�t have my trusty reference guide with me, (Bob W�s Book) and can�t remember the cut off point for the 3A.
The neck on the back of the head was probably connected to a heater at some point.   Heaters weren�t standard, so you see a number of plumbing techniques.  Most common is a shut off valve in this location.
An IAT 4008 is an unusual distributor.  Can you take the cap/rotor off and post a photo of the innards?  I wonder if the guts have been changed.
The radiator looks like a side mount for a 3A, but I�m not as familiar with this version.  Maybe some of our �Side Mount� folks will chime in.
Bottom Line: 70 years is a long time.  Parts and pieces get swapped.  Availability of original parts only recently (the advent of the world-wide-web) became easier to acquire.  Quite frankly, we are spoiled by it.  Back in the day, the owners did what they had to do to get them running�with what they could get locally.
« Reply #4 on: June 09, 2016, 02:57:01 PM »
�I found a port on the Carb that has a vacuum when the engine revs but no vacuum at idle."
[size=12]That would be correct. The vacuum is produced there only upon acceleration.[/size][/b]
Offline Mudviper
« Reply #5 on: June 09, 2016, 09:04:16 PM »
3J143B79� Is the �B� possibly and �8�?� If so, this is� a very late 3A block...Possibly a very early DJ3A block.� I don�t have my trusty reference guide with me, (Bob W�s Book) and can�t remember the cut off point for the 3A.
The neck on the back of the head was probably connected to a heater at some point.� �Heaters weren�t standard, so you see a number of plumbing techniques.� Most common is a shut off valve in this location.
An IAT 4008 is an unusual distributor.� Can you take the cap/rotor off and post a photo of the innards?� I wonder if the guts have been changed.
The radiator looks like a side mount for a 3A, but I�m not as familiar with this version.� Maybe some of our �Side Mount� folks will chime in.�
Bottom Line: 70 years is a long time.� Parts and pieces get swapped.� Availability of original parts only recently (the advent of the world-wide-web) became easier to acquire.� Quite frankly, we are spoiled by it.� Back in the day, the owners did what they had to do to get them running�with what they could get locally.
Here is a picture of the innards of the distributor
