Author Topic: Favorite dash cam???  (Read 3115 times)
« on: January 09, 2016, 04:24:47 PM »
A non-jeep question...do any of you have a dash-cam that you like and would recommend?  Thinking about getting one and the choices on Amazon are simply overwhelming.  Will use normally in my car and truck, but would like it to also be able to be adjusted for a (nearly) vertical Willys windshield too so I can get footage trail riding.
Most of them are from companies that I have never heard of and I have no idea which companies make the best cams.  The only ones I even recognize are Garmin and Cobra.  Any input would be appreciated!
Offline Jeff_M
Re: Favorite dash cam???
« Reply #1 on: January 10, 2016, 06:40:47 AM »
I have a kdlinks that I use in a tractor trailer.� Outstanding video quality, easy to use after the initial familiarization.� A little pricier than some.� Spare suction cup provided (they do wear out).� Very good customer service.� I'd buy it again.� No battery and it's 12v, so you have to keep that in mind with an older vehicle
Like you, I had no idea which one to get, but I took some time and read the reviews, which is why I settled on the KDLinks.
« Last Edit: January 10, 2016, 06:44:29 AM by Jeff_M »
« Reply #2 on: January 12, 2016, 08:23:04 PM »
Hey Jeff, thanks a lot for the input.  Would have thought more guys would be using them.  I think you mentioning that you went with a pricier one was good info.  There are a lot of cheap rip-offs out there and that isn't what I like to buy.  I went with an "Ion" dash cam which looks like it will do the job and be a good quality picture.  Thanks a lot!
Offline johnrb3b
    • Jeeps and stuff
« Reply #3 on: January 13, 2016, 02:46:49 PM »
Of course, the default choice for most people is the GoPro. Several models available via Amazon and a WIDE range of aftermarket accessories.
I have the Hero3+ Silver. It's in the $250 range depending on the bundle you buy.
I've mounted it via the included sticky thing to the almost vertical windshield of my JK. On the inside.
I bought an aftermarket mounting shell for it that isn't waterproof and allows cables to be connected through the sides. I can run it 'till the memory card is full when connected to a 12V USB adapter.
I also downloaded the GoPro app for my Droid cell phone so I can see what it sees while recording.
If you want to see some nice video taken with one, go to the Old Willys forum and look at vids posted by Pete.
Here's just one of many.
http://www.oldwillysforum.com/forum/showthread.php?6680-Klondike-Bluff-Trail-Moab
Or go to you tube and pull up videos from user idahoblueskies
« Reply #4 on: January 15, 2016, 04:21:37 PM »
I will go for the Go pro since you can use it anywhere anytime. It's now just for the dash.
