Well..you can set the altimeter anywhere you want, within limits..the current altimeter setting/barometric pressure will give you above sea level altitude..
If you are in Chicago and the barometric pressure is 30.02 then the altimeter will read about 680' above sea level with 30.02 in the window...
If you are in Boise and you set 30.02 in the same altimeter window it will read about 2800" above sea level...
The altimeter works off the current pressure, so weather changes will require that you reset the altimeter...
Now a small GPS like an Etrex will tell you everything you need to know...and it might even get you home if you get lost!
