Author Topic: New trailer!  (Read 5313 times)
New trailer!
« on: April 16, 2015, 09:52:15 PM »
Finally got my new trailer today! I ordered it back on the first week of February. It's a 7 ton 20ft Cam superline power tilt deck. Got it just in time for tractor/engine show season. First show for the Titan is the 25th! It's big enough for the Titan and the Famous or 2 jeeps or 1 55 Chevy.
Offline JeepFever
Re: New trailer!
« Reply #1 on: April 16, 2015, 10:50:42 PM »
Very nice!  . .  should be easy to load with that tilt function.
Re: New trailer!
« Reply #2 on: April 17, 2015, 06:32:16 AM »
Nice!  That looks like a tough work horse. It will serve you well.
Re: New trailer!
« Reply #3 on: April 17, 2015, 06:53:06 AM »
That is pretty sharp. Can you mount a winch or something on the front to assist with loading things onto it?
And should the IRS decide to audit your list of "business assets" it might be good to come back and delete this thread� ;D
« Last Edit: April 17, 2015, 06:53:17 AM by Ryan_M »
Re: New trailer!
« Reply #4 on: April 17, 2015, 07:36:20 AM »
Yes, I can add a winch to it. Thats what the steel plate is for. Ordered with that. ;)
Haha how come Ryan?
Re: New trailer!
« Reply #5 on: April 17, 2015, 08:07:27 AM »
Haha how come Ryan?
If you've found a way to make Jeeps, 55 Chevy's, and old engine legitimately tax deductible please share your secrets. Or better yet, are you hiring?  ;D
Re: New trailer!
« Reply #6 on: April 17, 2015, 10:22:26 AM »
Very cool trailer.  We have one at work.  I wanted one for my personal use too.  The one thing I was having trouble with was loading two Willys Jeeps.  Yours may be different than my work trailer though.
The tilt action is hydraulic and once the first Willys is driven on, the deck responds to the weight and will automatically move back into the horizontal position.  How the heck do I get the second Willys on to the trailer?
Yours may be power actuated, so you may be able to hold the tilt until both Willys are on the deck.
Re: New trailer!
« Reply #7 on: April 17, 2015, 11:08:19 AM »
Yes Tim they usually have an air dampener on them. I went with the hydraulic tilt just for that reason. Pretty expensive option but I'll only use this trailer in the summer so it should last many years.
No Ryan, that stuff isn't tax deductible. I wish it was!
Re: New trailer!
« Reply #8 on: April 17, 2015, 11:09:21 AM »
If you noticed in the picture with the deck tilted, the tires are off the ground. Makes changing a tire easy!
Re: New trailer!
« Reply #9 on: April 17, 2015, 11:10:14 AM »
I also got my winch mount bolted on and the deck stained.
Offline BMIC
  • Weekend Mechanic
Re: New trailer!
« Reply #10 on: April 17, 2015, 11:11:39 AM »
Nice rig GG, do you plan to make it 4WD?
Re: New trailer!
« Reply #11 on: April 17, 2015, 01:32:16 PM »
Nate, I want to pick your brain a little bit on this mount.  Is this steel plate welded to the frame or just a cap on top of the wood floor?  I have a tilt trailer also, but have been wanting to add a winch to it.  It currently does not have a steel plate like this, but I have been thinking of adding one somehow along with the receiver hitch you have pictured.  That way, I can have one winch I can swap between trailers as needed and not leave it on permantly.
Did you fab the receiver hitch or buy it?  Are you going to mount a battery in the front toolbox to power the winch?
Details man, details!!
Re: New trailer!
« Reply #12 on: April 17, 2015, 02:00:29 PM »
When I orded it, I got the winch mount, the steel plate on the deck. It is welded right to the framework. The wood doesn't go under it. There is a big 12v battery in tool box along with the power unit for the hydraulics. It also has a 110v trickle charger to charge the battery and I added a solar charger too for it. I made the receiver up. It's the only way to mount a winch so you can remove it easily.
Re: New trailer!
« Reply #13 on: April 18, 2015, 01:22:06 PM »
Put the new trailer right to work!
