Author Topic: Need your opinion on a trailer  (Read 3661 times)
« on: January 26, 2015, 08:44:25 PM »
I saw this trailer for sale not very far from me. He is asking 650$.
Look like at least a 194x-1950 trailer.
There is no sign or Plate on it. Is this can be a Bantam?
Don't know what to do.
Offline Jeff_M
Re: Need your opinion on a trailer
« Reply #1 on: January 26, 2015, 09:11:54 PM »
Whichever it is, the pics look quite nice--and the cover, depending on how long it's been on, has protected the floor from moisture/rusting.  Looks like it's worth the asking price.
« Reply #2 on: January 26, 2015, 09:30:56 PM »
It does look nice.......Military would have had a lunette...has the hitch been altered?
What to do?
Make him an offer!
Edit: I don't think the info on the side hooks was accurate, so I took it out...all the pics I looked at had four hooks per side....
« Last Edit: January 26, 2015, 11:23:34 PM by 1955CJ-5 »
« Reply #3 on: January 26, 2015, 10:13:36 PM »
Everything I see says Bantam except for the hitch. Looks like that was changed out at some point.
« Reply #4 on: January 27, 2015, 07:50:04 AM »
I vote M100 trailer. Brake handle style is different than earlier Willys or Bantam. You can still see where the storage box was mounted on the front. M100's also had those grab handles on the corners. M100 safety hooks were larger than Willys or Bantam.
I am not an authority on these so any of my observations could be wildly inaccurate but that's what I see...
Neat trailer either way.
Edit: Upon closer inspection it looks like the lunette is there except for the eye or the "doughnut". Someone likely cut the eye off and put that current coupler on. You could probably remove the coupler and weld an eye back on. Real or reproduction lunettes are huge money if you can even find them so having one remotely salvageable is definitely a plus.
« Last Edit: January 27, 2015, 08:03:20 AM by Ryan_M »
« Reply #5 on: January 27, 2015, 08:08:00 AM »
Here's a chopped lunette with a civvy coupler added.
And here's an M100 I found last fall with a slightly less permanent coupler addition. You can't see the actual coupler in this pic but you can see how it's bolted on. Don't we wish all PO's used this method???
« Reply #6 on: January 27, 2015, 11:19:25 AM »
I too see M-100 stuff.  Originally, the M-100 was designed to float, so there was no tailgate.  This trailer has had the back side cut out, then someone welded it back shut.
I would want to see the floor before I jumped on this, but if it looks good, $650.00 is a good price for that trailer�at least in the Colorado market.
« Reply #7 on: January 27, 2015, 07:59:26 PM »
Thank to all of you but i've been too late. He sold it for 500$.
Dawn.
Next time i will apllied the "tweaked" Texas law; "Shoot first then ask" it will now be "Buy it now then ask after" for me.
« Reply #8 on: January 27, 2015, 08:09:28 PM »
I have a whole shed full I stuff I bought using that policy. Want to buy any of it? You'd be the only one  ;D
Offline Birddog7
  • Still Plays With Willys
« Reply #9 on: February 12, 2015, 09:21:07 AM »
I have a whole shed full I stuff I bought using that policy. Want to buy any of it? You'd be the only one� ;D
Ditto
Birddog7
1945 CJ2A
1946 CJ2A
1948 CJ2A
1948 CJ3A
1956 CJ3B
