Author Topic: Jeep Fire extinguisher during WWII  (Read 10638 times)
« on: March 12, 2014, 04:29:06 PM »
I'm seeing a lot of fire extinguisher on ebay and many of them pretend to be made during WWII.
Is there a way to recognize it?
Any stamping on it?
I know Tim and Nate has one.
Offline SteveW
Re: Jeep Fire extinguisher during WWII
« Reply #1 on: March 12, 2014, 05:23:20 PM »
Here is the best place to go for that. Super knowledge.
http://g503.com/forums/viewforum.php?f=48&sid=cd7c020c003acff86470f238d3eb1cdd
You are right about buying a pig in a poke on WW2 stuff and most of it is intentional I believe.
« Reply #2 on: March 13, 2014, 09:13:05 AM »
After some research I found this;
http://www.vintagefe.com/general.html
« Reply #3 on: March 13, 2014, 01:49:24 PM »
I think the two I have, have the years stamped on them.
Offline p3ferris
« Reply #4 on: March 13, 2014, 01:53:59 PM »
The funny thing about the link Quebec jeep sent is that I have almost all the things that the jeep had before I got my jeep    I sm judt midding a couple of little things  :)
Offline SteveW
« Reply #5 on: March 13, 2014, 04:22:55 PM »
Here is where you have to be careful on things. The link mentioned above made reference to Pyrene being a supplier of FE's during WW2 however it appears they did not go into jeeps
http://g503.com/forums/viewtopic.php?f=48&t=218792&hilit=Pyrene
http://g503.com/forums/viewtopic.php?f=48&t=189182&hilit=Pyrene
You want to open another can of worms check out fire extinguisher brackets for originality
« Reply #6 on: March 13, 2014, 07:11:03 PM »
Here is a link listing the fire extinquishers that were common for MBs and GPWs. According to the TM9-1799, there were quite a few manufacturers supplying them for Jeeps.
http://jeepdraw.com/G503_Fire_Extinguishers.html
I have a Fire Gun -No."O".� Probably not correct for an M38, but would be acceptable for a WWII Jeep.
« Last Edit: December 10, 2017, 02:13:21 PM by athawk11 »
« Reply #7 on: March 13, 2014, 07:55:13 PM »
Thanks everyone. I have a lot of things to read. Is there a search function on the G503 forum ?
I find out that the FE is listed in the accessories part of my 1950 sales data book but it is hard to say which model it is.
On page 122;
http://jeepwillysworld.com/wp-content/uploads/2014/01/WO_Data_Book_1950.pdf
« Last Edit: March 13, 2014, 07:56:40 PM by QuebecJeep »
Offline SteveW
« Reply #8 on: March 13, 2014, 09:26:18 PM »
Yes there is a pretty good search function on the top right of the page, click on advanced search, then put in your keywords(s) not on the google line but on the forum line, skip author and all that stuff and pick the forum you want to search and stuff will pop up. You get the hang of it after a few times and learn to narrow down terms. It also helps to use the back arrow button as it will stay in the topic you are searching. Easier than my explanation is
« Reply #9 on: March 14, 2014, 08:32:17 AM »
For the search function, do you need to be logged into the forum?
I don't see any search on the top right corner.
« Last Edit: March 14, 2014, 08:34:03 AM by QuebecJeep »
Offline SteveW
« Reply #10 on: March 14, 2014, 03:25:16 PM »
You do need to log in for it to appear. It will be up in the green band where the g503.com message is. I am auto logged so didn't know that but I logged out and it disappeared.
« Last Edit: March 14, 2014, 03:30:05 PM by Googly_Moogly »
« Reply #11 on: March 18, 2014, 11:45:22 AM »
I hope to be able to get it shiny as Tim's FE.
Here is my new "toy" that I will install on my 3A;
« Reply #12 on: March 18, 2014, 12:14:14 PM »
Very nice Pascal.� There are many here that will suggest you leave it alone.� To each his own on that decision.
On mine, there seemed to be a clear coating of some kind that had deteriorated and developed the patina.� It required the removal of this coating to reveal the shiny brass.� I used a combination of 400 grit to 1500 grit wet/dry sand paper.� The label on the Fire Gun was also brass.� I carefully worked the sand paper on the label so I didn't remove the painted letters.� I was lucky that the paint was mostly recessed and the brass sat proud.� I don't know the make up of your label, so be gentle!� Once I got it clean, I shot it with a couple coats of new Clear Coat rattle can paint that I picked up at the auto parts store.
« Reply #13 on: April 16, 2014, 01:40:15 PM »
I'm not sure where to put it. I don't like the idea to drill hole in my fender like you Tim.
I think I will try to attach it to the seat somewhere.
« Reply #14 on: August 12, 2014, 08:47:25 PM »
Some updates;
I took one hour to clean it today.
Here is three pics; first is at startup, second 30 min after and the last is 1 hour after.
I don't know yet if I want to make it beautiful as Tim's one.
