Author Topic: Jeep Mystery?  (Read 3304 times)
Jeep Mystery?
« on: January 22, 2014, 07:17:57 PM »
My 3a came to me with an aluminum half cab. Someone along the way added a heavy board that was mounted vertically between the wheelhouses and which protected the rear panel of the cab.
I pulled this off months ago and today I moved it and happened to notice that the "brackets" they used to mount it were actually placards that had been cut in half..
The Osgood company made heavy equipment....this may be a clue to why my rear springs were bent over backwards!
Any ideas?
Offline p3ferris
Re: Jeep Mystery?
« Reply #1 on: January 22, 2014, 08:29:14 PM »
Jeep a trench set up maybe
Re: Jeep Mystery?
« Reply #2 on: January 22, 2014, 09:01:19 PM »
Maybe. That is sort of what I was thinking..
This had a rear PTO...the previous owner thought he remembered a mowing machine....
The bottom two leaves of both rear spring packs were bent over backwards....
Offline johnrb3b
    • Jeeps and stuff
Re: Jeep Mystery?
« Reply #3 on: January 23, 2014, 09:01:02 AM »
Wow, I'd like to see a picture of that.
 :D
Re: Jeep Mystery?
« Reply #4 on: January 23, 2014, 09:10:44 AM »
A mowing machine....rear spring bent...
Like this?
http://www.film.queensu.ca/CJ3B/Tech/KandKMower.html
Re: Jeep Mystery?
« Reply #5 on: January 23, 2014, 11:01:13 AM »
Wasn't there a pull behind type, or one that mounted on the drawbar?
« Last Edit: January 23, 2014, 11:02:53 AM by 1955CJ-5 »
Re: Jeep Mystery?
« Reply #6 on: January 23, 2014, 02:08:01 PM »
I don't see any reason why we would bent leaf spring like that but who knows.
I guess overweight on the rear is the reason. The two last leaf are not attached so they didn't bent back.
Offline SteveW
Re: Jeep Mystery?
« Reply #7 on: January 23, 2014, 03:37:23 PM »
There were bush hog mowers that attached to drawbar
Re: Jeep Mystery?
« Reply #8 on: January 23, 2014, 09:28:55 PM »
That could be it...I can visualize that jeep bouncing over uneven ground with some heavy mower pulverizing the vegetation...
The PTO drive shaft has dents where it hit the axle...
