Author Topic: Welder - what kind to get?  (Read 4205 times)
« on: January 15, 2014, 08:45:16 PM »
I know this has been kicked around before but I can't find any of it. I'm in the market for a welder for Willys related projects (tub and frame repair). I'm looking for a used one as I'm in no real hurry and am pretty sure I'll come across a deal on something.
I've barely even watched anyone weld let alone tried it for myself. I know nothing about it.
Athawk11 is an artist with whatever he uses. What is it?
Same for 1955CJ5. You constructed a 3A out of a pile of iron oxide dust. What's your weapon of choice?
And BMIC, haven't you recently been doing a little metal work of your own with a couple different welders? How's that going?
GarageGnome seems very proficient too but my guess is he's using something completely overkill compared to what I would be happy with.
I know there's few others here that have lots of experience too.
I don't need the best but I don't want something that will just lead to frustration and lousy results. What should I be looking for?
Offline SteveW
Re: Welder - what kind to get?
« Reply #1 on: January 15, 2014, 08:50:32 PM »
I couldn't be happier with my Lincoln Mig welder. It is an HD 3200, the HD just means Home Depot. They were made in USA and I am not sure if they still are. You be very careful of the low price foreign stuff as parts and consumables may be a problem. I had zero problems with it through my work and it was a lot of work on the tub. With regards to learning it is pretty easy and you can practice on almost anything and very inexpensive. You will get way better the more you do. Stuff i thought was pretty good early on at a later time I wish I could have done it over but that wasn't going to happen. 1 thing is get a self darkening welding hood.
« Last Edit: January 15, 2014, 08:54:01 PM by Googly_Moogly »
« Reply #2 on: January 15, 2014, 09:35:00 PM »
Hi Ryan,
The Miller-Matic 140 mig has worked well for me.....I had taken a gas welding class in high school, and we had an ancient (even then) Lincoln stick arc welder on the ranch....that was all the welding experience that I had...
It has an auto-feed setting so you dial in the gauge of steel and it sets the wire speed....at first I didn't like the auto feed, because basically I had no idea what I was doing....now I use it all the time....I'm still a rank amateur but the Miller works for me....I really don't know how I got along without it...!
It works on standard house current, and I've used it with a Honda generator....
There are lots of "how to weld" youtube videos.....watch several and draw your own conclusion from the info provided..then practice a little and go for it!
« Last Edit: January 15, 2014, 09:39:19 PM by 1955CJ-5 »
« Reply #3 on: January 15, 2014, 10:49:09 PM »
Hi Ryan,
Thanks for the compliment.
I have a Miller 125.  It's very portable and compact.  I use it with flux cored .35 wire.  With very little practice, it's very easy to use. Wire feed rate set to about 1.5 and amp rate dialed to "C" when doing sheet metal. Initially, this may seem a little "hot", but I didn't seem to get good penetration when dialed back to "B".
1/4" to 3/8" welds, moving from one side of the patch to the other.  If I'm in a hurry, I'll shoot some compressed air at the weld to cool it a little faster.  Moving around when welding sheet metal helps to reduce warping.
This welder can also be used with shielding gas, but I've had good success with the flux core wire.
A welder is a must have for any workshop.  Once you have one, you'll be looking everywhere for stuff to weld.
Offline BMIC
  • Weekend Mechanic
« Reply #4 on: January 16, 2014, 07:26:38 AM »
Ryan..... all the above comments have pretty much nailed it. I have been using a Lincoln 140 Mig welder and although frustrating at times my tub is nearly finished after replacing about 20% of it.
My mistakes have been leaving too much of a gap in some areas, not properly grinding/cleaning the panel surfaces and trying to weld a bead rather than several spot welds.
As stated above You Tube Video's or an assist from an experienced welder are of great value.
« Reply #5 on: January 16, 2014, 01:55:33 PM »
You will also need a good helmet. I bought an auto-darkening helmet the same time I bought the welder. Miller was offering a package discount so I saved a few bucks....
But get a good helmet, this is not the place to go cheap.....oh, and I opted for the one without the flaming graphics on the side!!
« Last Edit: January 16, 2014, 04:13:28 PM by 1955CJ-5 »
« Reply #6 on: January 16, 2014, 05:55:29 PM »
I used a Clarke mig welder for years and had very good luck with it.............until my Dad bought a new Miller last year.  Once I used it I was ready to throw my Clarke away for scrap metal!  However, I still have it and use it most of the time for rough work, but when I start to work on more sheet metal I will be very tempted to go "borrow" his!
I have also used a friend's Lincoln and like it a lot also.
So......to throw my .02 in I would go with either a Lincoln or a Miller welder.  Stick with a 110v unit that will run flux wire and you will be able to take care of most everything you'll encounter in the car hobby.  Also, make sure you get something you can find parts for locally!
« Reply #7 on: January 16, 2014, 08:35:06 PM »
Don't worry about not knowing how to weld profiently.  It will come.  I had never welded before and found an acient Montgomary Ward stick machine.  I was horrible with it at 1st then got a hang of it.  Then I bought a Lincoln 175 220V machine and couldn't be happier.  I self taught myself thru it.  I'm still not all that great at welding sheet material but a grinder makes me look good. ;).  Welding thicker stuff is pretty easy.
If you don't plan on welding anything over 1/4", a good quality 110V machine will do you good.  Flux core wire is 2X as much as MIG wire but with MIG you have to buy a bottle and gas.  Flux is nice in wind but you have clean the welds.  Mig makes a pretty, clean weld.  Its a user preference.
Brett
« Reply #8 on: January 16, 2014, 09:08:03 PM »
I appreciate all the input, guys....extremely helpful. I'm heavily trolling craigslist with some trade bait. I'll let you know when  I come up with something.
Offline ZekeD
« Reply #9 on: January 17, 2014, 11:59:37 AM »
Just trying to high jack this informative thread....
Does anyone have experience with a "Multiplaz" welder?� �It will weld almost anything, cast iron, aluminum, stainless and it does not use shielding gas.� �Was developed for the space program, not sure if it was ours or theirs.� �Expensive.... $1600, but no consumables.� BTW it will cut too.
Zeke
« Last Edit: January 17, 2014, 12:00:32 PM by ZEKED »
« Reply #10 on: January 20, 2014, 01:19:46 PM »
I love my Miller 251.
