Author Topic: Using 30 W non detergent oil in the tranny.  (Read 1095 times)
« on: June 25, 2013, 07:33:21 PM »
Some time back there were some discussions about the type of oil for the tranny and transfer cases. I and others had issues with any of the GL gear oils because most if not all have an EP additive that damages brass.
It was mentioned that mineral oil is what is supposed to be used and after some research I found that 30 W non detergent oil is the same as the recommended mineral oil.
I changed the oil in my tranny/transfer case and have driven it in cold weather and hot weather and have found it shifts much better than it ever has. I am happy to say that the 30 W non detergent oil is a good fit for our Jeeps and it won't hurt the brass blocking rings.
Re: Using 30 W non detergent oil in the tranny.
« Reply #1 on: June 26, 2013, 06:48:43 AM »
I havn't seen you here for a while Carl.
I have heard others doing the same with the 30W.  To bad the axles can't use it also, then we would only have to buy one oil for the whole rig.
« Reply #2 on: June 26, 2013, 08:49:52 PM »
I have been very busy getting the Jeep and motor home ready for Utah. I am just now getting everything about done.
Doing the brake job turned into a fiasco. Because my brake drums had been turned a little the rear short shoes would not adjust against the bottom of the drum. To cure that I had to order a full set of brake pads and change the short shoes for long shoes. Then I could get the brakes to adjust correctly. I prefer having long shoes on it anyway. I also had a leak at the rear steel brake lines after I got everything back together so I had to replace the lines. It seemed like everything kept breaking on the breaks.  ;D ::)
