I bought the 12K winch from Harbor Freight for $300 to load my Titan on my trailer. It works well for that. I cut half the cable off because if you don't spool it back just as the factory had it, it will bind and hit the control box. Also, the rating is much less on the outer windings (very outside one is 6K)on the drum than the inner ones (very inside one is 12K). It has no brake either, so when you free spool it, all the cable unwinds into a birds nest. I wouldn't use it for serious off road, but the occasional use and stuff like this, it is great. Still no match for the 8K Warn 8274 on the Jalopy.
Plus, it is cheap insurance. I would hate to run into a $12K engine with a $20K tractor because I was too cheap to buy a $300 winch...
The winch is mounted between the engine and tractor. It pulled the tractor up twice with only a good fully charged battery with no charging system.
