Author Topic: A flare tool that actually works!  (Read 1955 times)
« on: May 03, 2013, 11:57:35 AM »
So I have a confession to make......I'm a tool-o-holic.  :(  I really like to have a shed full of tools of every shape and size for every situation.  My saving grace is that I don't like "gimmick" tools or cheaply made tools that break the second time you use them.  However, I really enjoy when I find a tool that is well made, works great and solves a problem.
One such problem I have always had was trying to flare steel tubing properly to make gas, brake or vacuum lines.  The tool I always used was the kind that clamps on to the tube and then another piece screws down into the tube to make the flare.  It was always a challenge to keep the tube from slipping in the die....or the flare getting off center.......or the tube splitting or some other issue that causes you to throw your hands up.  >:(  I have used one enough over the years that I can usually get 1 out of 3 flares that are usuable.
That being said, I found a tool last night that actually works EXACTLY like it is supposed to and appears to be very well built..
http://www.eastwood.com/professional-brake-tubing-flaring-tool.html
The price is pretty steep, but they run specials all the time and I actually picked mine up for around $175 with free shipping.  I justified the price because I'm making my gas and vacuum lines for my '51 3a and then I have two other projects waiting in the wings that need all new brake, fuel and vacuum lines.  Anyway, last night I unpacked this tool, clamped it in my vise and within five minutes I had made two perfect double 45 degree flares!
If some flares are in your future, you should check this tool out.  ;)
Re: A flare tool that actually works!
« Reply #1 on: May 03, 2013, 01:04:33 PM »
Does it do the double flares on 3/16" tubing? I've never been able to those that great.
« Reply #2 on: May 03, 2013, 04:50:06 PM »
Yes, it has the dies for it, but I haven't tried any 3/16" yet.  I was only working on 1/4" tubing.
Offline p3ferris
« Reply #3 on: May 04, 2013, 10:22:47 PM »
Mine is military issue and I have never opened it     I have had it since 86
« Last Edit: May 04, 2013, 10:24:04 PM by p3ferris »
