Author Topic: Tools of the Trade  (Read 5869 times)
Offline BMIC
  • Weekend Mechanic
Tools of the Trade
« on: March 22, 2013, 01:02:42 PM »
While enjoying 1955CJ-5's "Too rusty to save" thread the past few weeks it occured to me that we often talk about out "tools" as much as we do our jeeps. I was given an old stick welder that I am so bad with I won't go near my 3A with it, but 1955CJ's thread has me pricing wire feed welders. Every time I see Nate's name on a thread I look at it just to see what else he has. Really Nate, showing ZEKED how to remove a tub with an excavator was interesting but can make one feel a bit under equipped at times.
Just thought it would be interesting to see what each of us deems nessessary to the 3A project.
Hopfully the photo you see below is my GEHL skid steer, it pulled the tub off my 3A, pulled the engine, front and rear ends, and the snow bucket makes a great spare work bench. And least I forget it has cleared 9 feet of snow from my driveway this winter.
Offline bretto
  • OD 3A cousin
Re: Tools of the Trade
« Reply #1 on: March 22, 2013, 04:13:14 PM »
Most important tool is a clear mind and patience.
Aside from that, I think barnone the most used tool I have used on my restoration has been my angle grinder.
Others (not in any order of importance):
A full ratchet set
open wrenches
welder
compressed air and tools
drill and drill press
various hammers
penetrating oil/spray
Im sure others will chime in on things I cant think of right off the bat.
Offline 3aJeeper
  • Luvs me a flatfender Jeep!
« Reply #2 on: March 22, 2013, 05:02:23 PM »
So far what I use most are the sockets/wrenches and the cut-off saw. Lot's of bubbafication needing to be removed and getting close to body work.
I foresee a lot of cut-n-replace patching like 1955CJ has been documenting (nicely done, btw!) on another thread.
Also, a new angle grinder is on the list.
1951 CJ3a
F-134 Hurricane engine
Offline p3ferris
« Reply #3 on: March 23, 2013, 06:36:16 AM »
I got a 4635 geil  3 months ago  loaded a 2 ton safe on my trailer last week.  very carefully I might add.   A torch was the most used item on my 2a  filling in all the rusted out  areas.  Several days  of it  Then the 1/2" and 3/4" wrenches.
« Reply #4 on: March 23, 2013, 08:10:52 AM »
Most valuable tool I have is a laptop set up on the work bench. I could have substituted anything else but there is zero chance I would have completed my rebuild without the power of the internet. The small plastic thing called a "credit card" also helped tremendously.
And while I do not have a flashy excavator, this trusty little Cub Cadet served me well when called upon as a "Jeep Carcass Relocation Vehicle".
« Last Edit: March 23, 2013, 08:14:28 AM by Ryan_M »
Offline F Bill
« Reply #5 on: March 23, 2013, 09:26:04 AM »
Cub Cadets and Jeeps are a great combination. And a non hydro CC like yours will definitely PULL. Is that still the original paint on your 108?
Offline Carls_jeep
« Reply #6 on: March 23, 2013, 10:19:35 AM »
The most important thing I need to work on my Jeep or anything else is the motivation to get started. I seem to find reasons to not do something until I really have to. I am a life time member of the procrastinators club but I never have sent my application in. That makes me one of their top professional procrastinators and they have always intended to send me the certificate to put on the wall if I ever get around to it if they ever send it.
 :)  8-)
« Reply #7 on: March 23, 2013, 10:48:16 AM »
.....Is that still the original paint on your 108?
It was repainted a few years back and looks pretty sharp. I've tried to replace the Cub twice now but keep going back to it as I really like it. It burst into flames last summer (with the help of a mouse nest tucked behind the engine) and it consumes oil at an alarming rate. It really deserves a complete overhaul which is somewhere on my lengthy project list.
The Cub has also been a willing donor of parts. You may recognize the seat here:
« Last Edit: March 23, 2013, 10:51:54 AM by Ryan_M »
Offline p3ferris
« Reply #8 on: March 23, 2013, 10:46:56 PM »
If that is a techumsah engine in that cub  you are in for a lot of trouble as they quit makeing techumsah engines and parts.  There is a place in texas that can get you some  but they are expensive to get
A head for mine was $399.
« Reply #9 on: March 24, 2013, 10:10:14 AM »
If that is a techumsah engine in that cub �you are in for a lot of trouble as they quit makeing techumsah engines and parts. �There is a place in texas that can get you some �but they are expensive to get
It's a Kohler motor. If it is not feasible to repair it I'm told I can re-power the entire tractor with relative ease. Again, it's somewhere on my project list and keeps getting bumped down a notch.
Offline p3ferris
« Reply #10 on: March 24, 2013, 10:24:33 AM »
Kohlers are a good engine.
« Last Edit: March 24, 2013, 10:25:26 AM by p3ferris »
« Reply #11 on: March 24, 2013, 12:08:59 PM »
Love that old Cub Cadet.
If there is a tub repair/restoration in your future,  the 'GO TO/MUST HAVE' tools are the...
-Angle Grinder
-Wire Feed Welder (or any type of welder)
-Don't forget proper 'Eye' and 'Hand' protection at all times while using above tools.
Angle Grinders may be the most versitile tool in any workshop.  Cutting, Grinding, Cleaning, Rust Removal, Sanding, Polishing.
This $60-$70 tool will save you hours and hours of time and effort.
Offline Matto
« Reply #12 on: March 24, 2013, 04:45:28 PM »
I agree with Ryan about the laptop on on the workbench although I still haven't figured where to put a OBD port on the Willys. ;)
A forklift is pretty handy to have around at times.
Matt
Offline Jeff_M
« Reply #13 on: March 25, 2013, 07:20:20 AM »
I purchased that Cub about 15 years ago and it was a low time machine that had been kept outside, so the paint was faded.  I rattle canned it with IH paint and it's amazing how well it's held up.  Ryan procured the 108 a couple of years back and put a new clutch in it.  Bill, I'm thinking I may have read your posts over on farmallcub.com; my user name is the same as here.
Offline BMIC
  • Weekend Mechanic
« Reply #14 on: March 25, 2013, 12:19:01 PM »
A laptop computer did not come to mind when I first asked this question but I must admit acess to this site, the 2A, Photo Bucket, down loads, and e-mail have been by far the most used on my 3A project. I often refer to the Willy's Repair Manual but just as often it is in a place I am not. Under the notion "nothing is impossible", could the repair manual ever be assessable through the 3A page?
