Author Topic: Pandora's Box  (Read 2021 times)
Pandora's Box
« on: August 23, 2012, 09:01:23 PM »
It seems Jeeps are like Pandora's box, every time you fix something it opens up another issue. I was putting rubber spacers between the frame and tub and had to remove the fuel tank to do a fix on the bolt under it. Well, the tank is patched with fiber glass so I am pulling the patch off to redo it. I will be looking for a good used tank now.
From what I have read the repro tanks are crappy and not a good fit. Next spring I will pull the tub and replace the top hats and much of the front floor and anything else that needs it.
Re: Pandora's Box
« Reply #1 on: August 23, 2012, 09:13:01 PM »
I have found ANY old mechanical thing is a Pandora's box....Our jeeps are older than most of us, and have already outlasted a couple generations of used cars like most 60's 70's and 80's cars. All have made it to the crusher by now, so I think we are doing pretty good with most of them.
Heck, back in the early 80's I was refurbishing a pretty popular brand of compact car on a regular basis, had to do clutches, brakes, and frame rot repair on most every Pinto wagon I bought, but they then lasted another 50 or so thousand miles. Just the way is is with old stuff. Good thing I switched to jeeps once i got older or they woulda put me in the funny farm a long time ago.
I have a 69 Beetle with all the same typical prioblems we all fight with the jeeps. Funny thing, the 69 I had as a teenage wasn't half this worn out. Go figure... ;D I know I am still the same tough guy I was at 17. I WISH!
Re: Pandora's Box
« Reply #2 on: August 23, 2012, 11:06:05 PM »
 ;D if we didn't love them we wouldn't own them but they should be more kind to use since we are trying to keep them alive.  ::)
Offline johnrb3b
    • Jeeps and stuff
Re: Pandora's Box
« Reply #3 on: August 24, 2012, 09:33:24 AM »
I have a 69 Beetle with all the same typical problems we all fight with the jeeps. Funny thing, the 69 I had as a teenage wasn't half this worn out. Go figure.
Well, the '69 Bus I had in the early '80s was already rotted out - Chicago winter salt, you know. POs probably never washed it - just like most POs of old Jeeps. I got it for free so no loss there. Eventually the bell crank bearing housing ripped off of the front axle - oops, no steering! Ack! Hillbilly fixed it and sold it for parts.
Re: Pandora's Box
« Reply #4 on: August 26, 2012, 09:35:28 PM »
Carl,
I know that 'Box' all to well.  I went out to fix the brakes...two years later I came back in with a completed project.
I bought my replacement tank from Walcks.  It is actually pretty nice.  The filler neck angle is dead on.  I did have to enlarge the holes in my floor pan a bit.   The drain and fuel line position was off a bit. (1/4").   In the tanks defense, I did replace the floor pans.  I could have set them a bit off.
Re: Pandora's Box
« Reply #5 on: August 28, 2012, 10:11:09 PM »
Pandoras box?  That's what my doc says about me!!!!!
