Author Topic: My lesson of crappy aftermarket parts  (Read 2834 times)
Offline NoCoWillys
« on: August 18, 2012, 05:36:44 PM »
So a couple weekends ago I rebuilt my transmission (t-90) and afterwards, I didn't like how the synchronizer assembly wasn't working quite right. �As a result I ordered a replacement assembly (synchronizer, hub, brass, springs and pawls) from a common willys part supplier. �After getting it, it looked great. �Was a much smoother action than my old rebuilt one. �My old one had new brass, springs and plates but was really really hard to slide. �No burrs or anything, just didn't slide well. � :-/ �
So today I went about installing the new assembly. �Luckily I hadn't installed the transmission back in the jeep and it was still sitting on my kitchen table. �I'm single can you tell? �Anyway, after installing it back on the main shaft I started to run into troubles. �I couldn't get the snap ring to fit into the grove. �The hub just wasn't going down deep enough. �In my frustration of trying to figure it out and going back and forth from the small pictures on my laptop, I thought the hub was on upside down. �So I took it apart, flipped it over and put it back together. �This time I could get the snap right on. �I wouldn't say it was a perfect fit, but I could get the snap ring to fit into the grove enough that I didn't think it was going to pop out. �Success! �Or so I thought. �Next after wrestling with the 14 needle bearings a couple times I was fitting the main gear back into the case. �All was good but I just couldn't get it to slide deep enough into the case to seat the rear bearing. �I had a little more than an 1/8" almost 1/4" before the rear bearing was even touching the rear bearing retainer. �>:( �At this point I went and played with the dog before I tossed the transmission out the window. �
Coming back I decided to get on my big computer with a big screen so I could make sure I was putting everything on correctly. �At this point I did determine I was stupid and I did have the clutch hub on correctly the first time. �So I pulled everything apart. �As a test I pulled everything off the main shaft except the retainer and the rear bearing. �It fit into the case and seated perfectly. �So I reassembled the main shaft with the clutch in the right direction and again I ran into not being able to put the snap ring on. � >:( �I suppose I could go and grind down the snap right just a slight bit and it would have fully seated (it was so close) but that didn't sound like a safe option to me. �
I pulled everything apart and started comparing the clutch and synchronizer. �They looked good but something was off. �I used my micrometer and measured the thickness of the clutch hub. �Sure enough, my original one was .835 and the new one was .837. �That .002 was about all I was off in getting the snap right in place. �So this time I went back to my original synchronizer and hub but used the pawles from the new assembly because my guess was the replacements I had gotten during the rebuild were what were causing the slide issues. �What do you know? �The snap right fit on perfectly! �This time when I installed the main gear into the case, everything slid together and the rear bearing seated perfectly. �Things are turning better and the synchronizer and hub slide like they should. �
So... very long story but in the end, I would have been better off saving my $70 bucks on this shiny new paper weight and gotten about $10 worth of pawles instead. �
Now if my luck would just improve with the transfer case (d-18) things would be looking up! �Oh but they aren't. �After getting everything stripped apart, cleaned up, painted, I was going to start assembling this morning with the master rebuild kit I got from Novak. �While making sure everything was there and ready to go I noticed the nice fancy new intermediate shaft I got from them wouldn't fit inside the bearings for it. �I then held it up to the case and the shaft was too big. Measuring it, it is a 1 1/4" shaft. �Mine is 1 1/8". �I double checked my order, yep I ordered the 1 1/8" kit. �I measured the bearings and they are for the 1 1/8" kit. �When they assembled the kit they put the wrong shaft in with it. �I'm sure they will make it right when I call them Monday, but I'm out another week waiting on shipping. �Anyone have a beer?
Cheers.
« Last Edit: August 18, 2012, 07:29:57 PM by NoCoWillys »
'53 CJ3a
Re: My lesson of crappy aftermarket parts
« Reply #1 on: August 18, 2012, 11:18:10 PM »
 ;D man, I know exactly how you feel. When I rebuilt my tranny/transfer cases I did a lot of searching and found out that you do not want to buy any tranny/transfer parts made overseas. I bought all my parts from Novaks and DeBella and told them I want ONLY parts made in the USA and NOS parts.
There are several threads here and on the CJ2A site that tell tales of woe from using parts from overseas. I know Novaks will make it right for you, they are a very good place to buy Jeep parts.
It's getting harder and harder to find NOS parts and parts made in the USA but they can be found in most cases.
Offline Macgraham
« Reply #2 on: August 19, 2012, 09:18:25 AM »
I found Tcase bearings made in Canada and they were good for fit. Not much time on them yet. Some of the parts suppliers I use to deal with are only interested with you're $$$ and not Jeeps at all. Just my opinion anyway.  mac
« Reply #3 on: August 20, 2012, 07:29:23 PM »
I can only wish this was the first time I've heard a story like this.  Rebuilding these beautiful little vehicles is a big enough challenge without having to deal with mismatched parts from suppliers.
Novak is a good outfit.  And we are all human.  Not to hope ill will on anyone, but I just wish they could occasionally show their human side on someone other than me.
Hmmm, I guess I got my wish.  Sorry NoCo ;)  In all honesty, I feel for ya' man.
Offline NoCoWillys
« Reply #4 on: August 20, 2012, 09:08:21 PM »
Thanks everyone.  Novak has already shipped the replacement shaft to me so I'll have it in a few days.  I suppose I should clarify who I got the crappy synchronizer assembly from since people are assuming Novak and I don't want them to take the blame for it.  I got it from kaiser willys.  The up side was Novak was really easy to deal with when I called them and didn't try to hassle me or anything.  They are making it right as quickly as they can.
'53 CJ3a
