I covered the cyl bores and did a three angle seat grind, checked the valves for contact, assembled the springs and adjusted the valves yesterday. Today figured out how to time the lube pump so the distributor rotor is where I want it. Then I installed the head studs, sprayed the head gasket, put the gsk and head on and started torquing the nuts. I got to 60 ft lb and was almost through the pattern and
one of the stud threads went soft.
ohhh that sick feeling I have had before when this happens.
I pulled the head, the gasket, the studs and cleaned the head and deck up, called Walcks and ordered 15 studs and nuts, called MSC and ordered 6 Keensert inserts. Tomorrow I will order another Victor 1023K head gasket and do a torque test on each head stud thread in the block to find any others that may fail. To be honest I was tempted to do that before I put the head on but thought, they all look good and I removed the studs from them when I had the block cleaned and checked. I should have listened to my inner feeling, something always goes wrong when I don't.
Well, I have a lot of things to do to it while waiting for the parts.
