Author Topic: Trailer and Tractor  (Read 1810 times)
Trailer and Tractor
« on: July 29, 2012, 10:29:44 AM »
This past spring we had a lot of discussion about what kind of trailer to buy, I finally got my head around that topic and thought I'd show you what I've got.  Also I've got a tractor on the trailer thats going to be in an auction on 8/16, so if you need a nice mower this one will be on IQbid.
I bought a PJ 3000 lb trailer, I bought the PJ because its a heavy frame, the 3000 lb traler is the same frame as their 5500 lb trailer, the only diff is the axle and springs, it has a fold down ramp that folds 180 degrees and is spring assisted, it also has two ramps built in as side frames on the front.  Additionally all of the side frames come off so you have a full flat bed if you wanted to haul a car.  I added D rings, and then I replaced the springs wirth 4500lb springs, just to add some comfort on those occasions you don't want visible sag.  Its nice, here's some photos, it does not have brakes, but I think I can add them later if I need to.
This is a 1950 ish Farmall B Narrow, Rebuilt motor, with a 59 inch Woods mower
Here she is all loaded and ready for the auction, the plow in the previous picture is an International Little Genius, 14 inch slat bottom plow.
Thanks for listening
Offline Dez
  • I drive it rusty.
Re: Trailer and Tractor
« Reply #1 on: July 29, 2012, 11:18:15 AM »
I would personally add brakes to the trailer. And in Some states your required to have brakes if the trailer weighs more then 1500lbs.
I Really love that tractor and Im thinking about buying one of those PJ's to haul the flatty around in. PJ makes some pretty heavy duty trailers. We have a fleet of them at work.
Located in Pinedale Wyoming
« Reply #2 on: July 29, 2012, 01:19:23 PM »
Nice tractor and trailer. Yes, I too vote for electric brakes over hydraulic.
