Author Topic: POSTING PICTURES  (Read 2006 times)
Offline jeffb
POSTING PICTURES
« on: November 09, 2011, 07:07:37 AM »
Could you guys help me out.  Would like to show some pictures of my project but I'm an ignoramous when it comes to this stuff.  Thanks for your help
Re: POSTING PICTURES
« Reply #1 on: November 09, 2011, 08:05:44 AM »
First you need your pictures on the web somewhere at a hosting servive like photobucket, webshots, �FLicker, etc...Once your picture is there, cut and paste the URL here...
Go to the url above and the third one is the inser image dealie.......[ximg][x/img] is the result once you click it. What you have to do is get your URL between the two IMG's � �like this [ximg]PUTYOURURLINHERE[x/img]
Here is a picture � �http://www.thecj2apage.com/forums/uploads/25/P1040010.JPG
Now I put it between the IMg things � � � [ixmg]xxxxxhttp://www.thecj2apage.com/forums/uploads/25/P1040010.JPGxxxx[x/img]
I put the xxxx's and x's in there so it didn't work and you could see the code.. Otherwise the dreaded red x or the actual picture shows up.
Here it is without the xxx
« Reply #2 on: November 09, 2011, 05:30:31 PM »
If you decide to use Photobucket then after you upload your photo to Photobucket put the cursor on the photo and a window will drop down. Move the cursor to the bottom that says IMG code and click on it. It will automatically be cut or copied. Then go to your thread or post and click in the text box. Then Hold down Ctrl key and click the v key. That will put your photo in the post.
« Last Edit: November 09, 2011, 05:32:11 PM by Carlsjeep »
Offline bayo500
  • You bought a what ?....
« Reply #3 on: January 01, 2012, 06:20:17 AM »
Thanks Carl, photobucket is easy when you read your post...
Offline johnnybravo
« Reply #4 on: January 12, 2012, 10:11:01 PM »
Folks, I posted instructions for posting photos from your PC file folders in the Website Feedback section.  Someone please try and see if they work for others.  I posted several photos to confirm.  Aboyanddog is trying to post a photo using the instructions.  I apologize in advance for any misguidance.
