Author Topic: Trailer hitch on Jeep  (Read 1605 times)
« on: November 27, 2011, 11:33:10 AM »
I just noticed something I have wondered about but forgot to ask. My Jeep has a hitch plate that is straight. You can see it in my thread about license plates. Calvins Jeep has a stepped plate, that is it has two bends in it so it can be put on with the ball high or low.
Now I am wondering is the Jeeps came with two plates. One that can be flipped for a high or low mount and a flat plate for a middle mount.
Does anyone know if this is so and where can I get the bent plate or do I have to make one for myself?
Re: Trailer hitch on Jeep
« Reply #1 on: November 27, 2011, 07:49:03 PM »
Only the very very early Jeeps had flat hitch plates. Can't really tell from the photo but I suspect yours was fabricated by a previous owner. I've got a "normal" offset plate you can have. The hole is kinda egg shaped from running with a loose ball.
« Reply #2 on: November 27, 2011, 08:13:49 PM »
I'll take it, I can weld and re-drill the hole, no problem. You still have my address and email don't you? Let me know the shipping cost and I'll send the money.
I just went and gave mine a close look see and it is home made. It is torch cut and a real good job at that. So good I never gave it a second look.
The CJ2A parts Jeep I have has a Rube Goldberg hitch on it.
« Last Edit: November 27, 2011, 08:18:18 PM by Carlsjeep »
« Reply #3 on: November 28, 2011, 08:49:03 PM »
Can one of you guys take a photo or get som dims on that part?  I need one as well and can get one made if I have some direction.
Thanks
« Reply #4 on: November 28, 2011, 10:23:24 PM »
When I get it from Bob I'll make a drawing and email it to you. What I'll do is make a template of the part without the bends and a side view showing the bends. That way you can have a blank sheared or burned out and then have it bent.
Do you want a template of my flat hitch plate? With both you would have three different heights for the ball.
« Last Edit: November 28, 2011, 10:23:59 PM by Carlsjeep »
