Looking very good, Carl..A couple things you may want to consider.. Instead of load leveling shocks, try an equalizing hitch setup. With the small FOrd pulling it, it will level things out and make the tire loading more equal between truck and trailer. I used to use a F-25o that had rear springs made from pasta or something equally soft, and the equalizer turned it into a beautiful setup.
Those ramps look great, would only take a pair of legs off the ramps ending a few inches above the ground to act as safety legs.
Got the same plate setup as you on mine, no problems with cops reading it or losing it, I did add a forward facing plate light on the angle iron upright you see just behind the fender.. ran the wire inside the angle, thru a drilled hole into the light. No �tickets for a missing license plate light that way.
What are you using for tie down points? EDIT, I see the welded on loops! Might want to put something straight back too...Adds to your options later..
Oh, and keep those tires covered when parked, the AZ sun is brutal on trailer tires..(You probably know that already, lol. )
