Author Topic: Installed my newly rebuilt carb today  (Read 5057 times)
« on: March 16, 2011, 02:18:55 PM »
I decided today was the day so I tore into the job. I had suspected in the past that I had a leaking head gasket because it seemed to have a hydraulic lock when I tried to start the Jeep. The past few weeks I have noticed a strong gas smell in the garage from the Jeep so I started thinking the carb was leaking gas into the cylinders and when I pulled the carb there was a pool of gas in the manifold. Solved that issue but I will still replace the head gasket later and I did get the head gasket with fiber on both sides from Autozone.
I put the rebuilt carb on and installed the throttle cable but the new cable does not lock out with a twist of the knob as I remember the M38 did. I will make a collar with a thumb screw to lock the shaft out where I want it to solve that issue. I got the Jeep started and warmed up and adjusted the idle speed and bleed screw. Then I took her out for a test run and she ran just fine. No hesitation, so the accelerator pump is ok and no dead spots during acceleration tests. It looks like I did all the adjustments at rebuild correctly.
Yeeee Haaaa, I celebrated by pouring a Spaten Oktoberfest beer into a frosty mug and began drinking it as I type this thread. The weather is getting better here and I am also working on the trailer to haul the Jeep with.
Annabel Lee and I will be driving around the county a lot this summer. She sure likes driving in the mud more than I do. �::) ;D
« Last Edit: March 16, 2011, 02:21:25 PM by Carlsjeep »
Re: Installed my newly rebuilt carb today
« Reply #1 on: March 16, 2011, 08:39:28 PM »
CJ-3As didn't have any positive lock on the throttle cable like some other models did. Sometimes the new replacement cables do not have enough friction to hold the throttle. I put some small kinks in the inner cable to add friction.
« Reply #2 on: March 16, 2011, 10:54:52 PM »
That's interesting Bob. Since some Jeeps had attachments that needed a set speed how did they make the throttle cable stay in one place?
Tomorrow I will machine a collar with a thumb screw to hold the throttle open any where I want it.
« Reply #3 on: March 17, 2011, 05:37:31 AM »
The optional governor would hold the engine speed constant regardless of load.
« Reply #4 on: March 17, 2011, 08:25:58 AM »
But wouldn't you have to set the throttle where you want the rpm's to be for the governor to then hold the rpm at that setting? That's the way the governor's work on the power unit engines I have worked on. When I set the throttle to the rpm I want the governor would then hold the rpm there as the load changed.
Offline jamesr
« Reply #5 on: March 17, 2011, 10:18:36 AM »
My 3A has a T handle throttle cable.  You screw the T handle in, and it locks the cable.  I use it as a vintage cruise control sometimes. Jim
« Reply #6 on: March 17, 2011, 02:35:11 PM »
Carl,
The governor has its own separate contol handle.
« Last Edit: March 17, 2011, 02:37:22 PM by Bob_W »
« Reply #7 on: March 17, 2011, 08:14:23 PM »
Oh, that would work.
« Reply #8 on: March 19, 2011, 11:35:36 AM »
Hi there Carlsjeep - in your post here you mentioned that you had a gas smell in your garage and that you resolved the problem with gas leaking down into the intake manifold. �What did you determine to be the problem? �Stuck float? �How did you fix this? �I have the same symptoms (gas smell) ever since I put my Carter back on last fall, and yet the old girl runs just fine (jeep, not wife). � Your 2 cents on this would be much appreciated.
« Reply #9 on: March 19, 2011, 01:32:24 PM »
The carb that was on the Jeep is the one it had when I bought it and I don't know when if ever it was rebuilt. I think the needle and seat started to fail and allowed gas to leak by after the engine was shut down.
I had a carb a friend gave me that I had rebuilt a few months ago so I put it on. I think I need to check the fuel pressure to see if I need to shim the fuel pump out to reduce the pressure.
The problem could be a bad float or bad needle and seat but I won't take it apart to see. I'll just put it with the rest of the parts I have for future use.
Your problem could be high fuel pressure, bad float or bad needle and seat.
« Reply #10 on: March 19, 2011, 01:44:24 PM »
Thanks a lot!  I'll check those things out.
