So I did make a few modifications to my CJ-3B, other than the front sheetmetal. Most are to improve the off-road capabilities.
The stock rear axle vent hole is welded up and a new vent installed on the top of the tube with a hose extending up high.
As mentioned above the tires are 7.50 x 16. To make them fit better in stock wheelwells the body has a 1" lift. The steering is upfront Jeep manual Saginaw. The steering box is mounted up high for clearance and the shaft goes over the front crossmember. Jeep optional front tow hooks are mounted on the frame rails. And there is the 12 volt electric Ramsey winch.
Frame mounted dual master cylinder with remote reservoirs. The front axle is a Jeep narrow track Dana 30 with disc brakes. "Narrow track" is actually wider than the stock D25 which allows for smaller turning radius, even with larger tires. 11" drum brakes are on the rear.
Since the body is raised one inch, the brake and clutch pedals are also moved up, providing a flat frame rail that's less likely to get hung up on rocks.
And the entire powerplant is up, along with the transmission crossmember for better ground clearance.
For safety there are seat belts and a roll bar.
