Author Topic: 64' CJ6 with factory Perkins  (Read 27452 times)
Re: 64' CJ6 with factory Perkins
« Reply #15 on: December 24, 2013, 08:22:29 PM »
Neat...Can't wait to hear it...you must post a video..!
Offline PeterS
  • It's a disease....
« Reply #16 on: December 26, 2013, 08:08:24 PM »
Continued on with the injector pump side of the engine. The secondary fuel filter housing is on the right of the photo towards the back of the engine.
Installed the rebuilt injector pump with low and high pressure fuel lines. The grey lines above the valve cover are the leak off lines. The leak off system feeds excess fuel that the injectors don't require back to the fuel tank.
It takes a long time to make sure all the lines are plumbed correctly. All these lines have been meticulously cleaned inside and out. Any contamination past the secondary fuel filter would be very bad for the injector pump and fuel injectors. Note the final components of the throttle linkage.
Here's a bigger view of the whole drivers side of the engine. The gray line that passes around the back of the block brings the fuel from the lift pump to the secondary fuel filter. This line is bigger than the high pressure lines. It looks to be 1/4" while the high pressure lines are 3/16". Sorry the pic is a bit fuzzy  ::)
« Reply #17 on: December 26, 2013, 08:20:26 PM »
Speaking of fuzzy.....is that a goat back there?
« Reply #18 on: December 26, 2013, 08:39:49 PM »
As if I don't feel dumb enough looking at any gas powered engine I am completely clueless looking at a diesel one. This is quite fascinating, please keep it up.
And yes, nice goat. A video of the goat riding in the Jeep would be superb.
Offline PeterS
« Reply #19 on: December 26, 2013, 08:58:15 PM »
That's Amma, an alpine dairy goat.� ;D
She'd come in handy pulling the jeep, not riding in the back. 8-)
This isn't a barn find, it's a barn build!
« Reply #20 on: December 26, 2013, 09:05:04 PM »
My goat experience is limited, but I think I remember a goat preferring a good push instead of pulling.. :D
« Reply #21 on: May 07, 2014, 08:55:31 AM »
Hi Peter,
This is what I'm looking to install in my DJ-6. I found a CJ-5 with a 4 192 perkins in it.
The seller want 500$ for the whole jeep.
http://www.cj3apage.com/cgi-bin/yabb2/YaBB.pl?num=1399429782
Do you have more info about that motor like manuals?
Thank
« Reply #22 on: May 08, 2014, 07:33:34 AM »
Sweet project for sure, love it!
