Author Topic: Colorado CJ-3A  (Read 8684 times)
Offline DanJ31
Colorado CJ-3A
« on: January 12, 2018, 12:21:50 AM »
Just wanted to post my new project a 1949 CJ-3A. It is in really good shape and just needs a little TLC. The goal of the project is to get it reliably running by this spring and worry about any cosmetics later. First project is rebuild the Carter WO carb, fuel pump, and brakes. It has spent most of its life in the Midwest and has been in the family since new. My Aunt and Uncle were SO gracious to let me be the next caretaker of this piece of history. It took a 1000 mile journey from Illinois to Colorado during a -15' cold snap, that was an adventure in itself. Hope you enjoy the build.
« Last Edit: January 13, 2018, 11:13:38 PM by danj31 »
Re: Colorado CJ-3A
« Reply #1 on: January 12, 2018, 08:49:58 AM »
Nice looking Jeep!
Welcome -
Re: Colorado CJ-3A
« Reply #2 on: January 12, 2018, 11:14:10 AM »
That IS a nice looking jeep!  Did you find it in Colorado?  Are you sure it's a 3A and not a 2A?  I only mention it because of the windshield frame.  Welcome to the 3A page, Dan.
Offline DanJ31
Re: Colorado CJ-3A
« Reply #3 on: January 13, 2018, 03:28:04 PM »
It is an early CJ-3A with some CJ-2A parts. The windscreen and the Diffs are from a 2A, not sure about the rest. I ordered a puller for the brake drums and got them off today for inspection. The drums and pads are almost new. I ordered a rebuild kit for just the cylinders. The carb is all apart and just needs a cleaning. Next I will have to turn a box of parts back into a working carb!
« Last Edit: January 13, 2018, 03:38:21 PM by danj31 »
Re: Colorado CJ-3A
« Reply #4 on: January 13, 2018, 08:24:55 PM »
What a great looking jeep! Lots of adventures ahead....
On the cj3apage home page there is a section for tech tips and specs. This is a link to some carb info.
http://www.cj3apage.com/index/Tech_Tips/carter_carburetor_rebuilding.htm
I rebuilt my carb but I had the advantage of also being the one who took it apart!
Scoutpilot, who posts here, knows everything there is to know about Carter carbs and no doubt can help you if you get in a bind.
Keep us posted...
Re: Colorado CJ-3A
« Reply #5 on: January 13, 2018, 08:53:39 PM »
Looks like a really nice Willys.  When I first saw it, I thought it was a 2A.  The grill is an early 2A.  And it also looks like it has a 2A frame.
Early 3As have the same axles as the 2A.  Dana 41 rear and the Dana 25 front.
Can you post a few more photos?  Driver seat frame.  A shot of the dash board area. An inside the cargo area of a rear wheel well.  And maybe a shot of the frame horns where they attach to the front bumper.
Offline DanJ31
Re: Colorado CJ-3A
« Reply #6 on: January 13, 2018, 09:20:08 PM »
Parts Cleaning
Offline DanJ31
Re: Colorado CJ-3A
« Reply #7 on: January 14, 2018, 11:51:53 AM »
Clean!
Offline mtnman37879
  • Plays With Jeeps
Re: Colorado CJ-3A
« Reply #8 on: January 14, 2018, 01:32:21 PM »
You know, behind those plugs are passages that may not be clean...
Offline DanJ31
Re: Colorado CJ-3A
« Reply #9 on: January 14, 2018, 06:56:50 PM »
Are those passageway rivets easy to reinstall. To remove them do you just drill them out?
Offline DanJ31
Re: Colorado CJ-3A
« Reply #10 on: January 19, 2018, 04:03:54 PM »
Shot of the Master Brake Cylinder, it will get a rebuild. Does it look stock??
Re: Colorado CJ-3A
« Reply #11 on: January 19, 2018, 07:16:47 PM »
Looks like the master cylinder has already been replaced at some time. Personally I wouldn't bother rebuilding anything but an original master cylinder, just replace it.
Offline DanJ31
Re: Colorado CJ-3A
« Reply #12 on: January 21, 2018, 10:18:09 PM »
A brown box showed up today! I pulled a late nighter and finished the fuel pump and carb. Now for the big test on the engine.
« Last Edit: January 23, 2018, 01:55:41 AM by danj31 »
Offline DanJ31
Re: Colorado CJ-3A
« Reply #13 on: January 25, 2018, 07:25:45 PM »
Doing some fluid changes today. The diff looks in good shape, just needs a wash. Any tips on cleaning out the diff? The pinion has a pretty good groove in it so I will re-sleeve it.
Re: Colorado CJ-3A
« Reply #14 on: January 25, 2018, 11:08:28 PM »
Looks good.  I need to be frank with you though.  I don't see a single piece of your Willys that would suggest it's a 3A.  Perhaps it's a late 2A that was sold in 1949.  Vehicles were sometimes titled in the year they were sold verses the year they were built.  Do you have the serial number?
