Author Topic: 1950 CJ3A restore  (Read 3659 times)
Offline Dajeepman
1950 CJ3A restore
« on: November 20, 2017, 11:41:32 AM »
 Got this gem for a reasonable price. It was running when I loaded it on the trailer. I got a lof of work to do on it. First is to rebuild the motor. It knocks under load. I got the front end tore down. And will be pulling the motor soon. Will upload pictures as I can get computer access.
I got a 1950 CJ3A work in progress.  had a 1998 Jeep Cherokee Sport with 6" lift Running 33"s. Locked and Armored up.
Offline Dajeepman
Re: 1950 CJ3A restore
« Reply #1 on: November 20, 2017, 12:02:39 PM »
Here what i have done so far. The wiring is complete disaster. Will have to order a complete wiring harness for it. Will need new guages and lots and lots of body work. The frame has lots of surface rust but no holes. Its in good shape. It will take lots of time since i dont have the income to do this quickly. Got to save up for even the small stuff. But in the end I will be happy that I restored a CJ3A to call mine.
« Last Edit: November 20, 2017, 12:09:31 PM by Dajeepman »
« Reply #2 on: November 20, 2017, 01:28:24 PM »
Looks like a good jump into the tear down.  The battery tray sure comes in handy at this stage.  A built in tool shelf. :)
Offline Dajeepman
« Reply #3 on: November 24, 2017, 06:06:08 PM »
I got the motor tore out. It's gona be a big expense or over haul
 so it be a while before I can get it running again. One the good note. The clutch was recently replaced. It's still fresh.
Offline Dajeepman
« Reply #4 on: November 25, 2017, 05:59:46 PM »
Took the pan off. I'm not sure what the person was thinking. I found out why my motor was knocking. Spun rod bearing. Look like they used 2 bearings stacked together. And they pistons been bored .60 over aready. I'm setting here debating on trying to find another block that's had not been bored over.
Offline Dajeepman
« Reply #5 on: January 14, 2018, 08:12:17 PM »
Cluster gear is toast. The drive gear that drives the gear that has broken teen it's chewed up too. Going to have to order a oem cluster gear and Novak rebuild kit.
« Last Edit: January 14, 2018, 10:15:07 PM by Dajeepman »
« Reply #6 on: January 14, 2018, 09:13:25 PM »
That's a lovely coffee colored cluster gear!
Good luck with your drivetrain rebuild!
dave
