Author Topic: The preservation of Hoover's engine  (Read 2097 times)
Offline JeepFever
« on: March 16, 2015, 11:13:54 PM »
I wish this was the preservation of the original engine,� but the engine that I acquired with Hoover had a cracked cylinder.� . . I bought a replacement engine that "ran when I pulled it",� but the PO stored it outside under a tarp,� and it suffered water damage.
The engine would not turn over,� �this is what I found when I pulled off the head.
I was able to free up the engine,� but obviously with this much rust in the cylinders,� I needed to disassemble and check for the extent of the damage.
The pistons are removed, and the cylinders honed.� I am going to try to preserve this engine, without sending to machine shop.� It is very clean inside,� so was obviously rebuilt recently.� The crank and rod bearings are in very good condition.
« Last Edit: March 16, 2015, 11:47:37 PM by JeepFever »
Offline JeepFever
Re: The preservation of Hoover's engine
« Reply #1 on: March 16, 2015, 11:45:52 PM »
I need to order a gasket set for sure,  probably a few valves,  and a set of piston rings (broke a couple when removing from #1 & #2 pistons).   I am wondering what size rings to order.   The pistons have 030 stamped on the top,  so that would seem to indicate this engine was bored .030 over.
I did some measurements with a 30 year old dial caliper, and snap gage.  My skills at measuring may not be extremely precise, but this is what I am seeing.
Top of piston:
3.131 to 3.136
Bottom of piston:
3.141 to 3.152
Cylinder bore:
3.150 to 3.158
If these measurements are accurate,  should I order new rings,  .030 over?
Measuring tools:
