Author Topic: DJ3A Just Purchased  (Read 104567 times)
Offline zooke581
Re: DJ3A Just Purchased
« Reply #105 on: March 29, 2014, 08:51:16 PM »
Got the drivers side floor panel cut and fitted.  Ready for welding tomorrow.
« Reply #106 on: March 29, 2014, 10:15:57 PM »
I can't believe how useful those little butt-joint clamps are.....
Looks great.....
Offline zooke581
« Reply #107 on: March 30, 2014, 09:17:11 PM »
Got more done today.  Drivers side floor panel installed and some hat channels.  Made a mistake on this but it is easily corrected.  See if anyone can find it.  That is why the pic shows both sides.
« Reply #108 on: March 31, 2014, 06:37:38 AM »
Lookin good. I don't see any mistake?
« Reply #109 on: March 31, 2014, 03:53:00 PM »
I can't see one either.  Can you give us a hint?
Offline PapaC
  • Amateur willys dj archeologist
« Reply #110 on: March 31, 2014, 07:30:19 PM »
Holes and capture nuts in hat channel.....
Trying to rebuild it one piece at a time because almost all of em were either missing or wrong!!!
Offline zooke581
« Reply #111 on: March 31, 2014, 09:53:24 PM »
PapaC is pretty much on the money.  The wider hat channel on the bottom is where the mistake is.
Offline PapaC
« Reply #112 on: March 31, 2014, 11:47:00 PM »
PapaC is pretty much on the money.� The wider hat channel on the bottom is where the mistake is.
The different offsets in the holes was the ONLY thing I could see that looked suspicious.  The rest of the work is awesome and I AM just a little bit jealous of your skills, especially the welding!!!
Offline zooke581
« Reply #113 on: April 01, 2014, 09:06:49 PM »
I had clamped the passenger bottom hat channel on and it popped off.� I picked it up reset it and welded it one.� Only after I welded the second piece on and rechecked for the next hat channel piece did I notice the hole and captive nut was not where it was supposed to be.� I had picked it up flipped.  Oh well :'( easy fix) and on with the show.
« Last Edit: April 01, 2014, 09:07:40 PM by zooke581 »
Offline zooke581
« Reply #114 on: April 01, 2014, 10:14:55 PM »
Worked on repairing the drivers side step.  It was rusted about the hat channel and where it attached to the body.  I cut a new piece and welded it to the step and then fitted it to the body.  Welding to commence tomorrow.  Still have a small insert section to weld in yet.  Then on to finish the tool indents.
Offline zooke581
« Reply #115 on: April 05, 2014, 08:37:09 PM »
Got the last of the hat channels for the floors in.  I added the small section to the drivers side that was in the passenger side on the DJ3A.  Adds a lot of extra support to the floors.
Offline zooke581
« Reply #116 on: April 05, 2014, 08:42:09 PM »
Worked on the last piece of the hat channel for the transmission hump.  Took that part off of my part jeep and fitted and welded it in.
Offline zooke581
« Reply #117 on: April 05, 2014, 08:49:49 PM »
Next I had to cut a patch for the hole the PO had put in the transmission tunnel for a bubba'd brake parking lever.  The panel had to have a small arc hand formed to fit before welding.  Panel clamps were used to hold into place for the welding process.
Offline zooke581
« Reply #118 on: April 06, 2014, 07:58:55 PM »
Worked on the transmission tunnel today.  It was different than a CJ2A and 3A as the DJ was not 4x4.  Then when the PO added 4x4 he cut it up real bad.  How it looked when I started today.
The tunnel from my CJ2A parts tub to be used.
Set in place and marked for cutout and fitment.
Welded in place.  Still need to do a small section to the right and the upper left where the steering column and brake pedal go.
Offline zooke581
« Reply #119 on: April 06, 2014, 08:05:41 PM »
Welded in place.� Still need to do a small section to the right and the upper left where the steering column and brake pedal go.
« Last Edit: April 07, 2014, 08:14:09 AM by zooke581 »
