Author Topic: taking this project apart  (Read 6053 times)
Offline malcomstrenko
« on: January 13, 2013, 09:52:58 PM »
pretty much all but tub,including PTO
on water pump boss                 more later, thx all         any info welcome
Re: taking this project apart
« Reply #1 on: January 15, 2013, 11:01:33 AM »
 :'( � �response to my post has been less than overwhelming �I guess I'm wondering about the potential this rolling frame and drivetrain may represent. Also wondering if this is the best place to ask these questions. Here are the basics,anyhow.Correct me on protocol please.Motor turns/springs look ok w/ some wiggled out ends in rear?/radiator correct?/PTO/ I've replaced rear crossmember/will rehab steering with advice/someone must have backed over a stump?/
I have the parts listed prev, but no tub. As you read this, tell me, what would you do? Oh yeah, I ain't a million bucks to work with. thx
Offline BMIC
  • Weekend Mechanic
« Reply #2 on: January 15, 2013, 12:29:31 PM »
Relax Mal, it's been my experience that these old jeeps can be restored for well under a million. Great pictures, you must have more into the camera then the Willy's.
Offline 3aJeeper
  • Luvs me a flatfender Jeep!
« Reply #3 on: January 15, 2013, 02:08:59 PM »
From your pictures (engine hoist, tool boxes, etc..)  it looks like you might be real mechanic...with skills and stuff.  If you think you can bring it back, then go for it!
I am certainly no mechanic so I'm intentionally ignoring an engine tear-down and rebuild. The PO's were actively using it for hunting (and were actual mechanics), so those components seem to be ok. The engine runs strong without smoke and the trans shifts ok, so I'm leaving that alone. Likely just whistling past the graveyard, but it's what I can afford and/or do myself. No million dollars here either.
Not sure what you'll have to do with the engine/trans.
The back end of mine looked a little worse than yours from what I can see in the pictures. You look like you still have good steel. I had to cut the rear passenger side shackle bracket off, reinforce the frame and weld a new bracket. It had a bubba-fied rear bumper ball hitch that I had to cut off. �Mine also looked like some backed over a stump and bent the lower draw bar supports...had to cut those off too.
Although mine does have a body, it's of little value other than the ID plate and maybe the gauges. So at least you don't have to wrestle the body off of that one! �:D I got mine for cheap and rebuilding best I can on the cheap too. But for me, that's half the fun.....ok, it's ALL the fun right now. :-)
AS down to the frame as I'm gonna get.....
Ignore the red circle...from a prior post. You can see the extra 10 inches of bumper garbage I had to cut off.
Not finished, but �cleaned up. Need to put on a cross member....
« Last Edit: January 15, 2013, 02:29:48 PM by JBCarney »
1951 CJ3a
F-134 Hurricane engine
« Reply #4 on: January 15, 2013, 07:16:11 PM »
gentlemen, thanks for your notes.       BMIC, I phones are great. Still
working on a million$. JB, nice project and patient approach. Question: Hurricane F head?
How is this fitting under hood? I see you have slightly tweaked body mount.Me too.
Cheers
Offline jamesr
« Reply #5 on: January 16, 2013, 11:34:55 AM »
The beginning of another 3A to hit the road.  Have fun!  It only costs and takes twice what you think!  Part of the joy. You'll love it. JamesR
Offline 3aJeeper
« Reply #6 on: January 16, 2013, 12:49:37 PM »
Cheers
Yep, from the 'it-was-there-when-I-bought -it' department - Hurricane F-134. I've determined it's from a early '50's Willy's truck. I swapped out the carb with a Holley 1904 and runs nicely. The Holley has a much shorter profile and leaves me some room to manufacture an air horn. Long way to go before I get to that part of the project. �
The PO solution to the taller engine/carb: cut a huge hole and bolt on an inverted oil pan.....very nice. :P
« Last Edit: January 16, 2013, 12:52:36 PM by JBCarney »
1951 CJ3a
« Reply #7 on: January 16, 2013, 05:48:50 PM »
when I built the body on this cj5 frame, I knew nothing of the motor height differences.
I only knew I wanted a flat fender look. Got to the hood and realized the conflict. Solution was a cake pan.
Still plowing the driveway 30 years later. Oil pan look is cool. Sending some pics and questions re my 3A.
Please see question/ answer section.
