The battery just sits there, just a metal support but no enclosure. The floor boards are just that..boards...plywood really...
Normal clutch and brake, and the lever is the emergency brake.
The normal and emergency brake rods you see each go back to separate cross tubes that span the frame, much like the clutch cross tube on the Willys. On each end of the tubes are two ears, 180� to each other. and from those ears one rod goes forward to the wheel brake and one to the rear. The emergency brake is the same but only has rods to the rear. The linkage on the front brakes is pretty cool, as it must allow the wheel to turn on the spindle..
This one will not be taken apart. I'll replace some of the worn and missing parts, but I like it just the way it is, dust and all!
