Author Topic: Vintage Enterprise Mfg Co. Coffee Mill  (Read 9485 times)
« on: March 14, 2014, 06:49:48 PM »
I spent a little time today pawing through some of grandma's stuff before it's all sold off as part of a substantial downsizing project for her. My wife spied this thing and insisted we take it home (very likely with some encouragement from Jeff_M). I begrudgingly lugged it out to the truck and home it came. I wasn't real excited about it but now that I'm going through it the thing is really quite cool.
It's big - the wheels are 19-1/2" in diameter and overall it stands 2' tall. The drawer is not original and the finial (likely an eagle) that was once attached to the top had been replaced by a lamp fixture. I quickly de-lampified it, which always seems like such a humiliating assignment for any once-noble piece.
The above noted exceptions aside, the rest of it is original, seemingly complete, and in excellent working condition. If I come across any bargains on 50lb sacks of coffee beans I'm ready to start processing.
Fram canister shown for size comparison purposes.
And Nate, no you can't have it to turn into an engine....
Re: Vintage Enterprise Mfg Co. Coffee Mill
« Reply #1 on: March 14, 2014, 08:20:28 PM »
Very cool. Looks like it should be hooked up to the PTO on a Willys. Could really get some coffee ground then  :D
« Reply #2 on: March 14, 2014, 08:28:29 PM »
Fits in nicely next to the oil filter canister....and what looks like a musket in the corner in case of attack...
« Reply #3 on: March 14, 2014, 08:33:55 PM »
I shudder at the thought of a oil filter in the house. Those things are always ready to leak oil - even when you are sure they are empty.
« Reply #4 on: March 14, 2014, 08:56:21 PM »
Bob - Have no fear, that oil filter hasn't seen wet oil in probably 40 years.
And good eyes Randy - That is a Robbins Kendall & Lawrence Model 1847 "Mississippi" Rifle leaning in the corner. It's an acquisition from this same downsizing project. I don't know much about it but it'll look good hanging next to my new coffee mill.
Now if I can ever finish up these Jeep projects so I can get onto some of this other stuff....
« Reply #5 on: March 15, 2014, 06:38:51 AM »
Coffee grinders don't make good engines.  ;D
« Reply #6 on: March 15, 2014, 11:06:09 AM »
I couldn't resist. I tore the mill apart last night.
Gross but in good shape.
The components were pretty well seized to the shaft. Since the wheels were too big to fit in the shop press, I had to resort to the trusty hammer and smashing block routine. A bunch of old coffee beans spilled out of that grinder plate once it came off the shaft. (Note the heavily grease stained welcome mat as a direct result of a month of Dana 44 rebuilding going on there. The wife is thrilled....)
I wire wheeled all the internal parts then scrubbed them down with hot soapy water. The inside of the housing also got a thorough scrubbing. The outside only got a very gentle damp wipe-down as I was afraid of damaging that paint.�
Pretty neat constant lubrication system here. This is an oil reservoir that originally had a small wick protruding up and in contact with the shaft. You can see the old congealed grease after I pulled out the remains of the dried wick. I'll have to find some new wick material and proper grease. For now, I've just lubed it with a small amount of silicone spray.
This key allows one to adjust how fine or coarse the grounds are. Tighten the key and it pushes on that silver collar increasing the outward load which pulls the two internal grinding plates closer together. There's a spring loaded collar on the opposite side of the axle which helps maintain a constant steady pressure.
First attempt and it worked like a charm. This thing has been a decorative lamp for at least 60 years, probably much longer. Today I'm drinking fresh ground coffee as I type this.
« Last Edit: March 15, 2014, 10:11:28 PM by Ryan_M »
Offline Jeff_M
« Reply #7 on: March 15, 2014, 01:39:50 PM »
You're sure you didn't clean that thing in the bathtub?
« Reply #8 on: March 15, 2014, 02:23:19 PM »
Very nice...
and as we have all learned from the Antiques Roadshow, don't polish off that nice patina!
Offline dat
« Reply #9 on: March 28, 2014, 01:30:34 PM »
I can smell the coffee brewing .
I like the old things, but I can see how the new ones save counter space in the kitchen
