Author Topic: Who here runs a 20R Toyota?  (Read 4736 times)
Offline Jesse
« on: August 15, 2013, 01:50:37 AM »
So my truck just quit running, its a '79 Toyota with the carbed 20R engine. It had been smoking a bit, but not bad. Today I got a huge plume of black smoke and I only made it down the road. It will run a little with the throttle wide open.
Right now I'm thinking the EGR is all clogged up, but I can't get another one. There is the option to block it off, but then all the other smog stuff would have to go as well. Not like it matters but that is a lot of stuff to block off.
Choke works fine... Could there be something else?
-Jesse
Re: Who here runs a 20R Toyota?
« Reply #1 on: August 15, 2013, 09:28:01 AM »
Check your carb..I believe a 79 would have a carb and it sounds as if it is running way rich....Anything that would cause a high float bowl fuel level could cause it, including a failed carb float or needle and seat.  If it has the composite float it may have gone bad and sunk. (THe holley Weber carbs used a foam plastic float that went bad regularly, I never owned a 20R for long so I didn't get  into the carbs...All mine were fuel injected.
I don't think EGR is the problem. If you suspect EGR as a problem you could always block it off and see, but black smoke sounds like way too much fuel.
Offline Jesse
« Reply #2 on: August 16, 2013, 12:09:28 AM »
I think the carb is doing fine I checked the mixtures and they are alright, and I have the choke wired open at the moment... I don't know, tricky situation.
-Jesse
« Reply #3 on: August 16, 2013, 07:44:38 AM »
Look down the bore of the carb when it is running and see if fuel is being dumped into the intake. Also check your oil for signs of gas in it.
If you are positive the fuel system is fine, do the usual ignition tune up checking, then go to  leakdown  and compression tests.
Black smoke is usually a sign of a too rich mixture or unburned fuel.......so I am not convinced he carb is fine. Is it running on all four cylinders?
Offline Jesse
« Reply #4 on: August 16, 2013, 09:49:54 PM »
Something for sure is going on with the EGR doo-dad. I took it off and blocked it off a bit, and even though the engine stumbled it quit smoking altogether. So I don't know, block it with a plate and do something with the vacuum lines? Or do you think I can clean out the EGR with something? I haven't had any luck getting a replacement as of yet.
Honestly I don't care about blocking it if that would work, the engine has nearly 400,000 on it as it is.
-Jesse
« Last Edit: August 16, 2013, 09:53:21 PM by Jesse »
