Author Topic: Single valve engine  (Read 4310 times)
Single valve engine
« on: April 08, 2013, 08:56:20 PM »
Now that we have a bridgeport, I have a new project I want to try my hand at, a single valve engine. Yes, it can be done. If you think about it, all you need is a place for air to get sucked in and blown out. The fuel can be injected via injector pump. The builder of this engine in the video below is on my engine forum and he absolutely loved my homebuilt one. So I wanted to try to built this funky engine to go with my other one! Mine will be of different design though since I don't have his skillz.  ;)
http://www.youtube.com/watch?feature=player_embedded&v=DWHTSdJZ3fA
Re: Single valve engine
« Reply #1 on: May 08, 2013, 05:57:06 PM »
I started working on the single valve engine today.
This is what will become the cylinder and piston. I'll get a cast iron sleeve to put in the pipe. The bore is 1.375" and the stroke will be 4.5".
There will only be one main bearing.
I've been collecting parts for it too. This in an old air compressor pulley that will be the flywheel. I also have a timing gear set from a junk Briggs.
« Reply #2 on: May 08, 2013, 09:03:04 PM »
What do you guys think of the data plate I'm going to make for it? I just have to learn how to etch brass plates now...
Offline 3aJeeper
  • Luvs me a flatfender Jeep!
« Reply #3 on: May 09, 2013, 08:29:10 AM »
Nice design. That'll really look good on a brass plate.
1951 CJ3a
F-134 Hurricane engine
« Reply #4 on: May 09, 2013, 05:56:00 PM »
Thanks!
I have a little snag. The sleeve I was going to use is out of stock. Might have to go with a 1.5" bore with a 1/16" wall sleeve instead of the 1.375" bore and 1/8" wall sleeve.
« Reply #5 on: May 11, 2013, 08:41:17 PM »
Ok, change of plans. I went to an antique machinery auction today and made a nice score, an air compressor for 10 bucks. It is perfect for the single valve engine project. When I'm done with it, you won't even be able to tell it was an air compressor. ;)
It couldn't be more easier to do this. The intake is right in the center of the head.
I pulled the head off to see how the exhaust valve worked. Well, that was easy enough to remove. The exhaust port is 1/2" pipe, which works perfectly. Lots of engines use 1/2" NPT spark plugs. It also gives a nice combustion chamber.
The cylinder bore looks perfect.
I started to disassemble to clean the old oil out and to start building it.
It has a cute little piston!
« Last Edit: May 11, 2013, 08:42:37 PM by garage_gnome »
