Author Topic: Building super Ted  (Read 37796 times)
Re: Building super Ted
« Reply #30 on: February 13, 2016, 08:00:35 AM »
It was bored 40 over, the crank was ground 10 under, 4 new valve guides, all new valves, milled the head, and cleaned everything.
« Reply #31 on: February 15, 2016, 08:40:40 PM »
Got the engine all all back together today along with my dual carb intake. There will be a write-up on making the intake once I finish the whole set-up on this jeep.
I also started work on the on board air mount. That's why I didn't paint the whole engine. There will be more on this to come as well.
« Reply #32 on: February 20, 2016, 01:40:29 PM »
Got the OBA and alternator bracket done today. I turned down a piece of 1/2" pipe in the lathe so it would fit in the original generator mounts. I only did the ends so there was a shoulder left to keep the pipe from sliding out. From there I made a plate that the compressor was mounted to.
I went to the local hardware store and got some turnbuckles for the tensioners. I made some bushings up in the lathe that fit inside the eyelets. I didn't want to use rod ends because I wanted to keep the "government repair" look. This compressor was nice to use because it had two pulleys.
« Reply #33 on: February 20, 2016, 08:00:04 PM »
After lunch, I got the engine all painted and a made up a custom throwout bearing for the T18.
Offline Birddog7
  • Still Plays With Willys
« Reply #34 on: February 21, 2016, 09:35:41 AM »
Nate, Nice job on adding the OBAC. Thanks for sharing. I like how you assembled the bell housing, tranny, tc, OD, on a engine stand was that just to paint it all?
Birddog7
1945 CJ2A
1946 CJ2A
1948 CJ2A
1948 CJ3A
1956 CJ3B
« Reply #35 on: February 21, 2016, 01:18:41 PM »
Thanks. I put it on there the put it all together because I had to take it all apart to get the input shaft out. It also made it nice to clean and paint as well.
I still have to swap the PTO from the original transmission.
« Reply #36 on: February 21, 2016, 08:21:58 PM »
Finally got the dual carbs done today.
« Reply #37 on: February 22, 2016, 06:34:00 AM »
"Finally". Yeah, what took you so long?  ;D
Offline Trenton
« Reply #38 on: February 22, 2016, 08:57:41 AM »
looking great, while i still think your level of tech as compared to my bench seat build is lacking a little ;)
in all seriousness id be interested to hear about any difference in engine performance/economy with the twin carbs (not that it will ever be a race car). as i am sorta new to flatties, was this ever done in the factory?
1950 CJ3A... Work in progress
« Reply #39 on: February 22, 2016, 12:44:20 PM »
You know me Ryan, I'm such a slacker!
Trenton, the red 3A you see in the background has had dual carbs for 3 years? I can't remember how long ago I did that. Anyways, they really wake up the Lhead. I noticed much more power and throttle response while getting the same fuel mileage. I used yf carbs from an fhead on that.
This want a factory option. Just something I came up with.
« Reply #40 on: February 23, 2016, 06:58:42 AM »
Got the engine dropped in last night and I made sure the OBA and alternator fit, which they did.
Offline JeepFever
« Reply #41 on: February 24, 2016, 12:02:56 AM »
I love your "themed" builds.  Thanks so much for sharing them!!
« Reply #42 on: February 24, 2016, 06:11:38 AM »
It keeps it more interesting that way.  ;)
« Reply #43 on: February 25, 2016, 09:16:32 AM »
Very good work!  Love the ingenuity.
« Reply #44 on: February 25, 2016, 09:02:20 PM »
Thanks Jeff. I want to try to keep everything looking factory.
