Author Topic: Steering column replacement ???? Anybody HELP!  (Read 2126 times)
Offline turkehunt
« on: February 03, 2012, 07:43:25 PM »
 ::)         Anybody got any tips on replacing my complete steering column with rebuilt steering box attached ???? I rebuilt a sreering column [ steering shaft , upper bearing replaced on shaft, rebuilt steering box & new pittman arm] rebuilt drag link . replacing tie rod ends. new bell crank and bell crank rebuild !!!!   Any tips on getting the new shaft up through the floorboard and what obstacles I likely will face  ?? exhaust clearance,brake lines etc.etc.    Thanks in advance for your replys  ! ;)
Re: Steering column replacement ???? Anybody HELP!
« Reply #1 on: February 03, 2012, 09:34:30 PM »
Here's how I did it, others may have a different approach. This is from an old post I made on the CJ2A forum. If you already filled the box with oil you'll have to wrap something around the shaft after you remove the outer shaft tube. With this method you do not have to remove the exhaust nor the oil pump.
Remove the outer column
Remove the pitman arm
Jack up the LF and remove the wheel
Remove the LF fender
Disconnect the brake light wires and pull out of the way.
Remove the brake pedal (trust me), just the pedal.
Rotate the steering box so the pitman shaft points upward
Lay the assembly on it's side above the frame with the shaft pointing at the hole in the firewall
Insert the shaft through the hole in the firewall
You should be able to maneuver the box into position, being careful of jabbing the front seat with the shaft
Bolt the box to the frame but do not tighten yet
The rest you should be able to figure out.
Just remember to center up the steering before putting the pitman arm back on
« Last Edit: February 03, 2012, 09:36:59 PM by rocketeer »
Offline turkehunt
« Reply #2 on: February 04, 2012, 05:15:14 AM »
Larry       Thanks for the great information ! This should speed things along.  8-)                               Jim
Offline Macgraham
« Reply #3 on: February 04, 2012, 08:58:00 AM »
Thanks from me too. I'm getting close to the same performance.
Offline turkehunt
« Reply #4 on: February 07, 2012, 04:22:34 PM »
Thanks Larry  :)              Just finished up installing rebuilt steering box after removing fender ,wheel as you suggested ! I was able to depress the brake pedal and get the column in  Worked GREAT  ;) Thanks so much for the help !!!    Jim
