Author Topic: Rear Brake Lines  (Read 5243 times)
Offline JimVillers
Rear Brake Lines
« on: November 21, 2015, 11:42:56 AM »
I am trying to figure out the attachment of the rear brake line that goes across the rear axle.  It looks like there should be a bolt hole in the top of the differential but I cannot find one.
The preformed brake lines did not come with clips.  I would think that it should have a clip that goes behind a cover bolt (like the front line) and it looks like it should have three bands to secure the line to the axle.
Can someone post a picture of the clips or straps or what ever is correct.
Jim Villers
Virginia Beach, VA
Re: Rear Brake Lines
« Reply #1 on: November 21, 2015, 09:32:03 PM »
Here is a pic, sorry its so grainy. But there is a brackets that has a tapped hole in it for a screw
« Reply #2 on: November 21, 2015, 11:11:34 PM »
I was missing my bracket too.  It's a pretty easy bracket to make if you have a little L-angle laying around.  Not perfect, but it works...
Offline JimVillers
« Reply #3 on: November 22, 2015, 07:37:15 PM »
Tim .... What is the clamp around the axle?� Is it correct?� Where did you get it?
I fabricated a simple bracket for the brass fitting.� I just need the clamps.
« Last Edit: November 22, 2015, 07:38:10 PM by JimVillers »
Jim Villers
Virginia Beach, VA
« Reply #4 on: November 22, 2015, 07:56:43 PM »
I have these on my 3A. Not sure if they are original but I believe they are. I've found them on other Willys too.
« Last Edit: November 22, 2015, 07:56:59 PM by Ryan_M »
« Reply #5 on: November 22, 2015, 08:27:23 PM »
Early CJ-3As had clamps, like Tim's photo. Later CJ-3As used the clips like Ryan's photo.
« Reply #6 on: November 23, 2015, 07:30:57 PM »
Thanks Bob.� I didn't know about the change.� The clips in Ryan's photos look pretty slick.
Jim, the clamps shown in my photo were included with the brake line kit I purchased from Walcks.� This kit is for the CJ2A and early CJ3A.
Your photo shows a Dana 41 rear axle which is consistent with early 3As.
« Last Edit: November 23, 2015, 07:33:49 PM by athawk11 »
Offline JimVillers
« Reply #7 on: November 24, 2015, 05:47:40 PM »
Tim ... I just figured out that the rear end was a Dana 41 when the rear cover gasket did not fit.
It does have tapered axles like the Dana 44.  I wonder if a prior owner swapped the axles for some reason.
Jim Villers
Virginia Beach, VA
« Reply #8 on: November 24, 2015, 08:14:12 PM »
Jim,
What serial number is your 3A?
Offline JimVillers
« Reply #9 on: November 28, 2015, 04:44:15 PM »
Tim ... My Jeep is CJ-3A 46300.
Jim Villers
Virginia Beach, VA
« Reply #10 on: November 28, 2015, 08:49:52 PM »
Based on your SN, your Willys was likely made in March or April 1950.  The Dana 41 is correct for this time frame.  The Dana 44 starts showing up on the 3A in late 1950.
