Author Topic: Wiper Arms - Range of Motion  (Read 2822 times)
Offline CJTHREEA
« on: October 13, 2016, 11:39:47 PM »
Does anyone know what the range of motion degrees should be?
My wiper motors are wiping through at least 120 degrees of motion...
Granted I have M131 motors but I understand these should work .... :o
Re: Wiper Arms - Range of Motion
« Reply #1 on: October 14, 2016, 01:34:10 PM »
CJTHREEA,
I don't know the actual range of motion, but 120-130� is about all you want.
Assuming they are positioned in the stock location, when 'parked' at 0�, the top of the wiper comes pretty close to the edge of the windshield when reaching the degrees mentioned above.
I can measure the angle tonight if you want it, but my motors are SF-616...The standard issue for the CJ3A.
Hawk
« Reply #2 on: October 14, 2016, 09:14:52 PM »
 Some arms can be adjusted to sit flat on the lower windshield rubber which will give you more range. 3A or M38, not 2A. John
Offline CJTHREEA
« Reply #3 on: October 16, 2016, 04:12:34 PM »
Thank you Hawk!
I'm thinking mine are getting around 120/130 as well.
Is starting position towards drivers side or passenger side?
I have a 2A but it has a 3A windshield so I figured it more appropriate to post here.
After looking at the size of the arms and blades I had the wrong ones too as I've seen the 3A windshields blades are 9" - just not sure if my arms are wrong too - I'll have to look for a model number or something on them.
« Reply #4 on: October 27, 2016, 09:14:34 PM »
[media]https://youtu.be/teZJN2eXz1g[/media]
