Author Topic: New member from the Netherlands  (Read 15219 times)
Re: New member from the Netherlands
« Reply #15 on: July 22, 2015, 07:39:48 PM »
Very cool crawl box. I've never seen one before. Sure wish someone would make a "Warn" underdrive!
« Reply #16 on: July 22, 2015, 07:59:57 PM »
Crawl box...  Crawl box...Hmmm.
Didn't think anyone would need to crawl any slower than 4-Low. ;D :)
« Reply #17 on: July 22, 2015, 08:07:06 PM »
In the rocks things happen very fast at the stock crawl ratio of 36.9:1. I'd like to have something in the range of 50:1 or better.
Offline Dutch_Jeeper
« Reply #18 on: July 25, 2015, 06:32:24 PM »
As far as the extra gearbox is concerned, unfortunatly i still have not found out anything more. All i can add is the instruction plate:
Been doing a lot of stuff the past week, put the body in Owatrol oil. It's a transparant oil that conserves the paint and any rust by sealing it, you can use it as is to keep the patina lookt or as a base for the next layer. It takes a while to fully dry but should leave a satin finish, if it stays to shiny i'll put on a flat coat. Painted the rest of the raised letters, still needs some touching up but not to shabby i think  :)
Also started on the seats, now i worked for a saddlemaker during 1 summer about 25 years ago and over the years did some small repairs on saddles and harnesses but never ever tried to refurbish seats.
Forgot alot of things that came back while working on the seat and made a couple of mistakes i'll be correcting for the next seat :-) It is'nt concours state, but it's a Jeep not a Ferrari but it does have aleather seat now  ;) ;)
So got me some leather skins, dug up my leatherworking tools from the depths of my workspace and went to work on it:
Biggest mistake, i worked from the inside out so the seams on the inside are nice and straight, but on the outside quite crooked  ;D ;D Lesson learned  :)
Not to shabby for a first try, good enough for now and if i apply the lessons learned correctly the next should come out a whole lot better. I do not have a machine so everything is hand stitched.
« Reply #19 on: August 12, 2015, 03:54:33 PM »
Today i got an @mail from a Dutch world war 2 and Jeep enthousiast. Besides keeping the memory alive of Europe's battlefields where so many died for our freedom, he also collects all kinds of information on military vehicles used in the Dutch army including Jeeps offcourse.
There are at least 2 CJ3a's with the original snowblower configuration. One was on display in an Aviation museum, not sure if it still is, and one somewhere in a depot of the Dutch national military museum. Here's what he sent me :)
All that remains on my Jeep of this setup is the extra gearbox and the split hood so they could maintain the engine without having to disassemble the driveshaft for the plow.
« Reply #20 on: August 12, 2015, 07:50:31 PM »
That may be one of the coolest Willys accessories I've ever seen.  I know someone in South Dakota that's going to want one of those.
Wow.  Thanks for sharing.
« Reply #21 on: August 12, 2015, 08:20:37 PM »
During some winters I need one of those CJ-3A snowblowers, very cool!!!!
« Reply #22 on: August 19, 2015, 03:46:16 AM »
So the 3a is at the shop for the gearbox, in the meantime i started on the trailer.
Red has to go  :)
Ral6014 Nato Yellow Olive satin finish.
Keeping the black borders and the red details on the frame and parts.
A little photoshop, yes the trailer gets its own pin-up  ;D
Stencils prepped
I'll probably start work on the pin up tonight and finish her over the weekend. I'll take pictures and make a write up for anyone interested in doing/trying this themselves. After that it is fingers crossed if the 3a is done in time for a Jeepclub weekend 29-30 of august.
« Reply #23 on: August 24, 2015, 12:31:48 PM »
So i have not had a lot of time, busy at work but have a week of leave coming up.
« Reply #24 on: September 28, 2015, 11:07:42 AM »
So it's back from the shop, t-case rebuild and a torough checkup. Lots of small things, brakehoses, wheelbearings, valves adjusted, some bad pieces of brakeline replaced, some wiring, starterring, generator allignment, belt. But it's back and drives better then ever.
Learned that the previous owner was carefull with the Jeep but did not drive it that much about 900 miles in the past 6 years, probably because all of the little issues that needed attention. Imho standing still doing nothing is far worse to an old car then making some modest mileage in it. Long drives instead of alot of short trips. Offcourse using it as a daily is something else, but 99% of problems and a lot of maintenance can be avoided by using it regularly instead of once a month or every few months.
Anyway, took it to a Jeepclub event yesterday and did some moddest offroading for the first time in the CJ3 It performed wonderfull. Left behind quite a few build TJ's and JK's in the mud. Wonderfull to see and experience what lightweight and narrow wheelbase offer in the kind of terrain we drive around here. I was always convinced lighter is better.
It's ussually muddy tracks and mudpits dug by wide Jeeps and Patrols on 33's and up trying to power through  ;D the little CJ3 simply drives outside those tracks on the hard ground. The narrow mudtires are wonderfull to I was pleasantly surprised and had the best time offroad so far though i did hit a piece of burried concrete which knocked off a wheelbearing cap. It was to oval to put back and could not get it back into shape. Luckily this was at the end of the day and i used ducktape to protect the bearing on the way out and home. I'll have to get a few and carry them for spare, just a 5 dollar part luckily.
There is only one issue i need to fix and that's power :-) not engine wise though :-) but for the navigation and action cam lol they dont charge on 6 volts hahaha, talk about modern day complaints lol so probably some loose batterypacks stuffed in an ammo box should be enough for more then a few hours of filming and navigating.
Made a little video, gives a good idea about the kind of terrain we deal with over here mostly. This event was on an old abandoned military base at airfield Weeze in Germany.
Unfortunatly my camera was down (see problem above  ;D ) so i have only eye wittnesses, but i also drove the little 60hp mighty Willy over the old airforcebunkers, about 35 to 40 degrees climb over 20-30 meters long, effortlesly. I did not even need to push it to climb up. The descent on the other side was a different story with those 4 drumbrakes  ;D i can clearly sense a discbrake upgrade coming during the winter :-D
Next event is 3 days of offroad fun and lots of beer in 2 weeks. About 500- 600 4x4's of all brands and kinds will have fun on roadbooks and 4x4 playgrounds on route, live music and campfires in the evening.
Dumped some period music under the video, i think it is'nt to shabby for some fast editing after a long day  ;D enjoy
https://youtu.be/8RaOC6rOrkw
« Reply #25 on: September 28, 2015, 12:11:44 PM »
Nice video, DJ.  You have many talents.  Good music, but, of course the sound of a little Lhead is good too!
Offline OkieFarmJeep
« Reply #26 on: September 29, 2015, 02:29:02 PM »
That Jeep is pretty cool!  My 3A has a jeep a trench drive and it crawls like that- in fact it has an external clutch so you can be outside it like that- but not to hijack this thread.  I bet your one happy papa bringing it home!  Keep those old parts in it and working as it sets it apart as unique!
« Reply #27 on: October 15, 2015, 06:58:11 AM »
Back from a fantastic weekend, the Willys performed absolutely wonderfull. Those narrow mud tires again left behind TJ's and JK's on fat 33" and larger tires :-) Could not be happier. Though it could use a bit extra height since the tires are higher then the standard ones so they touch the inside of the wheel wells sometimes.
I saw a subtle 2,5 inch lift leafspring kit from Rancho. Anyone familiar with them? Think it's exactly what i need for the added height without going to much away from stock looks. The added height from the tires alone is already an aprovement over stock as another CJ3a on stock wheels bottomed out on places i had just enough clearance.
Anyways, turns out those 500-600 4x4 was a bit off, there were almost 1200 during the entire weekend. 27 different brands of 4x4's and about 7 different nationalities, even some Aussies on a trip around the world in a 4x4 motorhome :-)
1st a link to a site from a photographer and reporter specialized in offroad events. Though in Dutch the pictures should be enough :-) 2nd is just pictures from another profesional.
http://www.terrein.nu/Actualiteit/De-Offroad-Budel-files---Copy
http://www.eye-catch.net/STOCK/Offroad-Budel-2015/Offroad-Budel-2015/i-PZ4852b/A
And a collection of mine:
One of the terrains found during the roadbook tour
3 generations
Nicely build CJ3b, not much stock except for the chassis
Me in the pit :-)
Happy and tired after 3 days off fun, excitement, free hamburgers from strangers, and all the attention in the world :-)
My old Jeep, now owned by a good friend:
Probably his way of driving, because i never had problems like this:
Front upper control arms sheared off both at the same time!? Luckily a Jeeper had some tube style ones lying at home for replacements.
Back on track he went for the mudcup only to be back 15 minutes later in a cloud of white smoke  :o :o again luck was on our side and someone brought a spare radiator  ;D
As for the Willys, not a thing, ran like a champ the entire weekend. Spend the last 2 days cleaning her up, greasing and checking the fluids, she's ready for the next event or tour, whatever comes first  ;D
« Reply #28 on: February 19, 2016, 02:39:47 PM »
Hey! I know it's not the same setup as the snow-blower but in the ad's they speak about an under drive transmission needed for this setup. Look on the second page in the square requirements.
I though it would be interesting.
http://jeepwillysworld.com/blog/2016/02/19/jeep-bros-sno-flyr-1959/
It's not the same setup if you take the secondary Willys F-4 engine or the Wisconsin VG4D engine.
I also find a Jeep snow-blower used at the airports that look similar to yours. It's on page 15 in this booklet http://jeepwillysworld.com/blog/2016/02/19/jeep-in-public-service-1966/ , first top left picture.
« Last Edit: February 19, 2016, 04:13:13 PM by QuebecJeep »
