Author Topic: how to grease a rear axle bearing  (Read 146 times)
Offline tow hook
« on: November 04, 2026, 11:50:35 AM »
i saw a video the other day, on how to grease your rear axle wheel bearings.
 in the video it states to grease it till grease comes out the little hole on the top of the axle tube. so i when a head a checked mine out. i have a 62 3b, maybe it's for earlier jeeps ? i didn't see such a hole. any thoughts ?
 thanks brian
Re: how to grease a rear axle bearing
« Reply #1 on: November 04, 2026, 02:42:56 PM »
The hole is almost certainly plugged up with dirt.  When my jeep was still new to me, I pumped and pumped with no grease coming out of the hole.  I eventually got around to checking the brakes and inside the brake drum, the grease retainer was full and the overflow was all over the brakes.
If you want to see the grease come out of the hole, it will be necessary to open it first.  Also note, even then, if the seals are worn, the grease will, just like everything else, take the path of least resistance.
« Last Edit: November 04, 2026, 02:46:32 PM by Rus Curtis »
