Author Topic: new crown throw out bearing makes noise  (Read 256 times)
Offline tow hook
« on: June 01, 2026, 10:12:43 AM »
my old throw out bearing made noise ( when not en gauged / at a stop light  ) when i first got my jeep running adjusted the linkage. the noise when down but never away totally.  after 2500 miles it was pretty quite. no grease leaking out...   so when the trans was out over winter i fixed the leaks etc. i put on a new crown throw out bearing. sounds worse then the first bearing. i'm temped to try and drill a hole in it, and add more grease. i  have maybe 5 miles on the new bearing. any thoughts ?
 thanks
Re: new crown throw out bearing makes noise
« Reply #1 on: June 28, 2026, 06:45:59 PM »
I'm curious that the bearing's make noise when not engaged.  The Clutch Release Bearing (throwout) shouldn't be making contact and therefore just sitting on the front shaft housing (Main Drive Gear Bearing Retainer).  When you press the pedal, the bearing contacts the clutch Release Levers and begins to spin.  It spins at engine speed as long as you keep the pedal pressed.  Then it stops spinning when you let the pedal out and the bearing is no longer in contact with the clutch.
Do you have the clutch pedal adjusted to have 1.5" free pedal before you feel the resistance from making contact?
When you separated the transmission and engine, did you replace the pilot bushing also?  Odly enough, the pilot bushing would be exact opposite of the throwout bearing; quiet when driving but possibly noisy when clutch is engaged allowing the flywheel to spin on a stationary Main Drive.
I do believe if you open the sealed throwout bearing, it will eventually fail.
As I've not been on for a while, I'm curious if you're still working this or did you resolve it?
Offline tow hook
« Reply #2 on: June 29, 2026, 12:17:28 PM »
the noise when away after 40 miles, i did check the free play of the pedal. all seems well. the pilot bushing was new 1800 mile ago.
as for now i'd call it good. glad the forum is back on again :)
« Reply #3 on: June 29, 2026, 02:13:15 PM »
So the solution was to get in it and drive?!
That's the type of fix I like!  Keep it rolling!
Offline tow hook
« Reply #4 on: July 01, 2026, 12:08:31 PM »
i just hope the throw out bearing i just did on my 48 goes as easy. i won't know for another year or so till it runs.
