Author Topic: dana 18 speedp cable input oil leak  (Read 5954 times)
Offline tow hook
« on: October 08, 2025, 09:39:24 AM »
whats the best way to seal up a leaking speedo cable were it enters the dana 18  t case ?
 it's leaking at the threads. i put on thread sealer. and then the nut backed off. and my speedo wasn't working. i have resealed it. and i will let it sit for longer ( even though i wanta drive it in this nice weather )  i'm hoping for a better out come.
 what have you used for this oil leak ?
 thanks brian
Re: dana 18 speedp cable input oil leak
« Reply #1 on: October 08, 2025, 11:07:45 AM »
I have not seen nor read of a technique or product to seal the cable housing to the transfer case.  I do know how difficult it is to remove the threaded cap when it's put on too tight.
From my own personal experience, I haven't had any leakage from the threaded cap of the cable housing.  Also, from personal experience, I've been fooled many times on where a leak originates.  One technique is to add dye to the oil and then you can see where it's coming from.  For me, spraying/cleaning/drying works really well and is cheaper.  Once all the oil is removed, a dry paper towel dabbed in the area (start high and work lower) will show where the leak originates.
How full is your transfer case?  If you remove the filler cap, does the oil: Pour out? Drip out? Not drip?
The threaded cap should screw all the way down so that there's no play in the housing (I believe THIS is the seal to the housing at the transfer case).  Are the threads clean on both the cap and transfer case?  Could the cap be cross threaded or damaged?  Since the cable is supposed to be serviceable vs. permanent, sealing the cable housing cap may cause it to be non-removable.  So, if you have issues with the cable itself, it won't be easy to fix (here I'm thinking of a broken cable down near the transfer case).
Sometimes these things can't be resolved while sitting on the jeep (our best efforts to contort and squeeze into a confined space just isn't enough - and repairs on a work bench become more desirable.   If you have eliminated everything else or need to buy time for a better attempt later, you could smear some thick grease into the cable housing cap and reinstall it back onto the transfer case.  It may slow down a small drip, shouldn't be incompatible with the gear oil and won't interfere with removal later on.
Offline tow hook
« Reply #2 on: October 09, 2025, 11:11:29 AM »
 the case is full, maybe a tab over ? i may need to take an 1/8" off the cable if i tighten the nut too tite the speedo cable stops working i assume it s bound up. the threads are fine.  i have a long ride at gettysburg next weekend, and want make sure things are good. i marked the nut and will drive it today.
 thanks i may use the grease idea
« Reply #3 on: October 09, 2025, 02:27:32 PM »
I'd be real interested in learning why your cable binds when you tighten the cap down.  Not being able to tighten the cap may be the cause of the leak.
If you pull the cap off the back of the speedometer, can you grab and pull the inner cable all the way out?
Offline tow hook
« Reply #4 on: October 10, 2025, 10:52:52 AM »
 the cable is trim to fit, so i took another 1/8 off and the cap is down tite. the speedo is working great . need to add 1 more round of thread sealant
Offline tow hook
« Reply #5 on: July 02, 2026, 11:13:56 AM »
i did put grease on the threads and the oil has stopped leaking. i still want take 1/8" off the cable. thanks again :)
« Reply #6 on: July 02, 2026, 01:34:33 PM »
The grease seems easy enough.  If you notice any hopping on your speedometer needle after trimming, it's possible it may be a bit too short.
The hope is this fixes all the cable stuff so you can focus on the next issue.
