Author Topic: what type of stone do you use when you rehone a go devil  (Read 1544 times)
Offline tow hook
« on: October 20, 2023, 02:26:49 PM »
my go devil is in need of a refresh, after watching some videos. i've learned that old engines use cast iron rings, and the hone should have course stones in it.  as i learned fast the rings, and the stones must match.....
i called k.w. and asked if there rings were cast iron. he had no clue, and he had a shop do the work for his engine.
so were did you get your rings? and what type of stone did you use ? fine, med. or course ?
 thanks for any info
Offline tow hook
Re: what type of stone do you use when you rehone a go devil
« Reply #1 on: November 10, 2023, 01:47:32 PM »
i read and watched videos for fine, medium and course stones. any tips ? my bores are just glazed over.
 thanks
Offline Mark W.
  • Chug A Lug
« Reply #2 on: November 13, 2023, 01:49:19 PM »
So your going to rehone your cylinders and put in new rings without boring the cylinders? have you measured for taper and run out?
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
Offline tow hook
« Reply #3 on: November 15, 2023, 11:40:55 AM »
i haven't acquired the tools to measure the bore yet.. the bores are very glazed. ( like glass )  after i find out my specs. if all is right, i plan to hone / cross hatch the bore. then measure for piston fitment and get rings......  if it needs a machine shop, it will sit for a long time before it gets the love it needs :(
Offline tow hook
« Reply #4 on: November 29, 2023, 02:54:26 PM »
i got the gauges needed to measure the bores, i'm going over tomorrow and will post the results.
Offline tow hook
« Reply #5 on: November 30, 2023, 03:01:48 PM »
i did 8 measurement per bore bore number 1   lowest to highest 80.39 to80.41 mm num 2 80.36 to 80.65mm num 3   79.77 to 80.57mm and num 4 80.08 to 80.69mm target number is 80.391 to 80.442 i wish there was a .50 over vs going all the way to .60 over
